i2c_master_cmd_begin Timeout Error lasting 1000 ticks, despite much shorter timeout setting
squirtle321
Postby squirtle321 » Mon Oct 17, 2022 1:56 pm
Hi there,
I've got a block of code which is occasionally blocking one of my tasks for a full second, leading to horrible jitter. Upon further investigation it seems like i2c_master_cmd_begin(...) is blocking for a full second. I have the parameter ticks_to_wait set to be much lower, which according to documentation should set the maximum ticks to wait before issuing a timeout. The issue is intermittent, but leads to instability in my firmware.
Here is the code:
    i2c_cmd_handle_t cmd = i2c_cmd_link_create();
    i2c_master_start(cmd);
    i2c_master_write_byte(cmd, AS5600_ADDRESS << 1 | I2C_MASTER_WRITE, 0x1);
    i2c_master_write_byte(cmd, REGISTER_0, ACK_CHECK_EN);
    i2c_master_write_byte(cmd, (AS5600_ADDRESS << 1) | READ_BIT, ACK_CHECK_EN);
    i2c_master_read(cmd, (uint8_t*) &s.half_word, 2, I2C_MASTER_LAST_NACK);
    i2c_master_stop(cmd);
    TickType_t pre_ticks = xTaskGetTickCount();
    esp_err_t ret = i2c_master_cmd_begin(i2c_port, cmd, 2);
    if (ret != ESP_OK)
        ESP_LOGE(TAG, "READ FAILED, TICKS = %d, ERROR CODE = %s", xTaskGetTickCount() - pre_ticks, esp_err_to_name(ret));
    i2c_cmd_link_delete(cmd);
Logs:
READ FAILED, TICKS = 1000, ERROR CODE = ESP_ERR_TIMEOUT
Anyone seen this issue before?
eliott
Re: i2c_master_cmd_begin Timeout Error lasting 1000 ticks, despite much shorter timeout setting
Postby eliott » Mon Oct 17, 2022 8:39 pm
I have a the same problem and I think it's related to master write at first.
My signal shows that the master I2C doesn't transmit the 9th bit for slave ACK. My slave send an ACK but the master timout after the eighth bit. You can see on the attached image that my slave maintain ACK.
Then after 1 second wait the master send the databit.
My code was working at first EPS8266, now I'm on ESP32-WROOM-E (on ESP32-Ethernet Starter kit)
I updated today IDF from 4.2 to 4.4.2 last release, same problem.
I check with the documentation everything seems to be okay.
Same problem if I use ACK_IGNORE.
#define I2C_WRITE 0
#define I2C_READ 1
#define ACK 0
#define NACK 1
#define ACK_VERIFY 1
#define ACK_IGNORE 0
esp_err_t MASTER_I2C_WRITE(uint8_t adress, uint8_t * p_data, uint8_t lenth, uint8_t close_action)
	while(flag_busy);
	flag_busy=1;
	if(i2c_handle == NULL)
		i2c_handle=i2c_cmd_link_create();
	i2c_master_start(i2c_handle);
	i2c_master_write_byte(i2c_handle,(adress | I2C_WRITE), ACK_IGNORE);
	i2c_master_write(i2c_handle, p_data, lenth, ACK_IGNORE);
	if(close_action==STOP)
		i2c_master_stop(i2c_handle);
		i2c_error=i2c_master_cmd_begin(I2C_NUM_0, i2c_handle, (1 / portTICK_PERIOD_MS));
		i2c_cmd_link_delete(i2c_handle);
		flag_busy=0;
		i2c_handle=NULL;
		if(i2c_error != ESP_OK)
			ESP_LOGE(TAG, "Write STOP: %s",esp_err_to_name(i2c_error));
			return ESP_FAIL;
	return ESP_OK;
Thank you for help.
long timeout.JPG (154.41 KiB) Viewed 2118 times
eliott
Postby eliott » Mon Oct 17, 2022 9:35 pm
At my side the problem has been solved by enable interrupts: ESP_INTR_FLAG_INTRDISABLED is not OK
This works:
i2c_error=i2c_driver_install(I2C_NUM_0, I2C_MODE_MASTER,0,0,ESP_INTR_FLAG_LOWMED);
Users browsing this forum: No registered users and 128 guests
