I've written some asynchronous code (using the Arduino core) that relies on the number of microseconds that have passed to perform certain actions.
I am currently using esp_timer_get_time() to get the number of microseconds, but there appears to be a fair bit of overhead to that function: when I call it repeatedly in the loop, depending on my clock frequency, it takes anywhere from 10-30us just to return.
I'm hoping for something a little more granular - optimally something that takes <1us to return. I was hoping I could find the registers that the system clock updates every tick and just read the register holding the lower 32 bits (since I know there are fancy things that are going on to freeze-and-read to get all 64 bits in sync), then divide by clock speed (since it doesn't vary for my application).
For 240mhz, I show that 32 bits should hold ~17.9 seconds before overflow, which should be plenty for me. Unfortunately, I can't figure out where to access this register. I've tried some of the FRC registers that I dug around, but they didn't seem to be changing at all. Also looked at other TIM0 registers, but they weren't changing either. I read *something* about needing to prompt an update by writing a register, but I figured I'd ask here if anybody had more information.
I'm not dead set on reading a system clock register, I just need a way of asynchronously and accurately tracking time, ideally with 1us resolution (though anything better than 10us is an improvement).
Thanks!
Fastest system timer/clock
Re: Fastest system timer/clock
Maybe you could use a timer that interrupts (alarms) at 1 usec and set up an interrupt to just increase the a variable each time.
Then just read that variable. When using the idf 64 bit timers are available.
Hi Snipeye,
Could you please attach your sdkconfig file and the code you used to benchmark esp_timer_get_time? Also please mention the version of IDF you are using.
Reason i am asking is, we have a test case that this function returns in less than 1us. So 10-30us sounds like way too much.
Hi, following up here after a long while.
I'm using the Arduino IDE right now, actually, and I found that the actual cause of the ~15us delay was the housekeeping in between loop() iterations. Wrapping my inner loop in a while(1) resulted in significant speedups, and the function call to esp_timer_get_time() is actually sufficiently fast.
Thanks for following up!
Users browsing this forum: No registered users and 130 guests
