Using IDF 4.4 and 5.0 in VC on Windows
I have some projects already developed on IDF 4.4, but now I have a new one and I want to use 5.0. Is there any way to use two different IDF versions with Visual Code extension?
Re: Using IDF 4.4 and 5.0 in VC on Windows
Yes, you want to use VSC portable.
https://code.visualstudio.com/docs/editor/portable
After you do this, and install Espressif's extension, Click on advanced and install the esp stuff to another location.
Looks like it is exactly what I was looking for! Thanks!
Using Espressif docker versions are much easier and cleaner.
https://hub.docker.com/r/espressif/idf
And VS Code supports developing inside a container
https://code.visualstudio.com/docs/remote/containers
Users browsing this forum: Google [Bot], Majestic-12 [Bot], tharanilc and 208 guests
