SHA-256 comparison failed:
Calculated: 2b5934d67e29f49b386b3a8671a900a5698c3ea9ec14cf7180ac2386d42b412e
Expected: c71fd8098647f7f10f5f00266b33ff2dd9928133340f81ebe7e51c21a472fb48
Attempting to boot anyway...
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x1654
load:0x403c9700,len:0xbb8
load:0x403cc700,len:0x2f88
entry 0x403c9954
I (43) boot: ESP-IDF v4.4.2-dirty 2nd stage bootloader
I (43) boot: compile time 19:35:01
I (43) boot: chip revision: 0
I (45) boot.esp32s3: Boot SPI Speed : 80MHz
I (50) boot.esp32s3: SPI Mode : DIO
I (55) boot.esp32s3: SPI Flash Size : 8MB
I (59) boot: Enabling RNG early entropy source...
I (65) boot: Partition Table:
I (68) boot: ## Label Usage Type ST Offset Length
I (76) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (83) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (91) boot: 2 factory factory app 00 00 00010000 00100000
I (98) boot: End of partition table
I (102) esp_image: segment 0: paddr=00010020 vaddr=3c070020 size=12f10h ( 77584) map
I (125) esp_image: segment 1: paddr=00022f38 vaddr=3fc96ac0 size=041d4h ( 16852) load
I (129) esp_image: segment 2: paddr=00027114 vaddr=40374000 size=08f04h ( 36612) load
I (139) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=6968ch (431756) map
I (216) esp_image: segment 4: paddr=000996b4 vaddr=4037cf04 size=09bb4h ( 39860) load
I (225) esp_image: segment 5: paddr=000a3270 vaddr=50000000 size=00010h ( 16) load
I (226) esp_image: segment 6: paddr=000a3288 vaddr=600fe000 size=00020h ( 32) load
I (239) boot: Loaded app from partition at offset 0x10000
I (239) boot: Disabling RNG early entropy source...
I (254) cpu_start: Pro cpu up.
I (254) cpu_start: Starting app cpu, entry point is 0x40375330
0x40375330: call_start_cpu1 at C:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_system/port/cpu_start.c:160
I (0) cpu_start: App cpu up.
I (268) cpu_start: Pro cpu start user code
I (268) cpu_start: cpu freq: 160000000
I (268) cpu_start: Application information:
I (271) cpu_start: Project name: wifi_station
I (276) cpu_start: App version: 1
I (281) cpu_start: Compile time: Aug 16 2022 19:34:45
I (287) cpu_start: ELF file SHA256: c3bde964363e84d4...
I (293) cpu_start: ESP-IDF: v4.4.2-dirty
I (298) heap_init: Initializing. RAM available for dynamic allocation:
I (305) heap_init: At 3FC9E760 len 000418A0 (262 KiB): D/IRAM
I (312) heap_init: At 3FCE0000 len 0000EE34 (59 KiB): STACK/DRAM
I (319) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM
I (325) heap_init: At 600FE020 len 00001FE0 (7 KiB): RTCRAM
I (332) spi_flash: detected chip: gd
I (382) spi_flash: flash io: dio
I (383) sleep: Configure to isolate all GPIO pins in sleep state
I (383) sleep: Enable automatic switching of GPIO sleep configuration
I (433) cpu_start: Starting scheduler on PRO CPU.
Users browsing this forum: Bing [Bot] and 32 guests
