使用ESP32-MINI-U模组无法builtin JTAG调试
sxliujin
Postby sxliujin » Mon Aug 08, 2022 11:45 am
使用同样的代码和工程配置挂载合宙9.9元的开发板JTAG是可以的,环境使用的是Espressif-IDE 2.5
现在工程PCB使用的是ESP32-C3-MINI-U模组
观察硬件差异只有合宙9.9元的开发板的FLASH是外置的
ESP32-C3-MINI-U模组是片内FLASH
在工程中已经关闭了内存保护,但模组还是挂不上JTAG,日志如下:
大概能看出来是openocd对flash的操作有什么问题
Open On-Chip Debugger v0.11.0-esp32-20211220 (2021-12-20-15:43)
Licensed under GNU GPL v2
For bug reports, read
Info : only one transport option; autoselect 'jtag'
Info : esp_usb_jtag: VID set to 0x303a and PID to 0x1001
Info : esp_usb_jtag: capabilities descriptor set to 0x2000
Warn : Transport "jtag" was already selected
Flashing C:/Espressif/frameworks/esp-idf-v4.4/workspace/BMS76952_4S/build/partition_table/partition-table.bin at 0x8000
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : esp_usb_jtag: Device found. Base speed 40000KHz, div range 1 to 255
Info : clock speed 40000 kHz
Info : JTAG tap: esp32c3.cpu tap/device found: 0x00005c25 (mfg: 0x612 (Espressif Systems), part: 0x0005, ver: 0x0)
Info : Examined RISC-V core; found 1 harts
Info : hart 0: XLEN=32, misa=0x40101104
Info : starting gdb server for esp32c3 on 3333
Info : [0] Found 8 triggers
Error: Failed to get flash maps (4294967295)!
Warn : Failed to get flash mappings (-4)!
Error: Failed to get flash size!
Error: Failed to probe flash, size 0 KB
Error: auto_probe failed
Error: Failed to find bank 'esp32c3.flash'!
** Flashing Failed **
-1
Started by GNU MCU Eclipse
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'.
Error: attempted 'gdb' connection rejected
shutdown command invoked
ESP_Gargamel
Re: 使用ESP32-MINI-U模组无法builtin JTAG调试
Postby ESP_Gargamel » Tue Aug 09, 2022 1:47 am
你应该是用 ESP-IDF Windows Installer 安装的 IDF 开发环境,直接用命令行,IDF CMD,或者 IDF PowerShell,先读一下 MINI 模组的 flash id:
$ esptool.py flash_id
esptool.py v3.3-dev
Found 3 serial ports
Serial port /dev/ttyUSB0
Connecting....
Detecting chip type... ESP32-C3
Chip is ESP32-C3 (revision 3)
Features: Wi-Fi
Crystal is 40MHz
MAC: 7c:df:a1:59:77:b8
Uploading stub...
Running stub...
Stub running...
Manufacturer: 20
Device: 4016
Detected flash size: 4MB
Hard resetting via RTS pin...
然后:
$ openocd -f board/esp32c3-builtin.cfg
Open On-Chip Debugger  v0.11.0-esp32-20211220 (2021-12-20-15:42)
看一下运行结果。
同时也提供一下合宙开发板的输出结果。
sxliujin
Postby sxliujin » Tue Aug 09, 2022 12:39 pm
MINI模组结果如下:
esptool.py v3.2-dev
Found 2 serial ports
Serial port COM6
Connecting...
Features: Wi-Fi
Crystal is 40MHz
MAC: 84:f7:03:bc:ef:3c
Uploading stub...
Running stub...
Stub running...
Manufacturer: 20
Device: 4016
PS C:\Espressif\frameworks\esp-idf-v4.4> openocd -f board/esp32c3-builtin.cfg
看起来和您的结果是一样的
合宙9.9开发板结果如下:
esptool.py v3.2-dev
Serial port COM4
Connecting...
Features: Wi-Fi
Crystal is 40MHz
MAC: 60:55:f9:79:ad:1c
Uploading stub...
Running stub...
Stub running...
Manufacturer: cd
Device: 6016
合宙和我的模组虽然相比您的日志报了多了ERROR,而且DEVICE的编号不一样,但是合宙的开发板确实能挂上JTAG,下面是在Espressif-IDE中terminal的信息
Info : Flash mapping 0: 0x10020 -> 0x3c060020, 59 KB
Info : Flash mapping 1: 0x20020 -> 0x42000020, 331 KB
Info : Auto-detected flash bank 'esp32c3.flash' size 4096 KB
Info : Using flash bank 'esp32c3.flash' size 4096 KB
** Programming Started **
Info : PROF: Data transferred in 63.829 ms @ 62.6674 KB/s
** Programming Finished **
** Verify Started **
** Verified OK **
** Flashing done for partition_table/partition-table.bin **
Flashing C:/Espressif/frameworks/esp-idf-v4.4/workspace/BMS76952_4S/build/bootloader/bootloader.bin at 0x0
Info : PROF: Data transferred in 363.543 ms @ 55.0141 KB/s
** Verified OK **
** Flashing done for bootloader/bootloader.bin **
Flashing C:/Espressif/frameworks/esp-idf-v4.4/workspace/BMS76952_4S/build/BMS76952_4S.bin at 0x10000
Info : PROF: Data transferred in 6122.88 ms @ 74.4747 KB/s
** Verified OK **
** Flashing done for BMS76952_4S.bin **
** Resetting Target **
0
Info : Flash mapping 0: 0x10020 -> 0x3c060020, 66 KB
Info : Flash mapping 1: 0x30020 -> 0x42000020, 324 KB
Info : Using flash bank 'esp32c3.irom' size 328 KB
Info : Using flash bank 'esp32c3.drom' size 68 KB
Warn : Prefer GDB command "target extended-remote 3333" instead of "target remote 3333"
semihosting is enabled
sxliujin
Postby sxliujin » Tue Aug 09, 2022 1:54 pm
另外我更新了openocd 到最新的v0.11.0-esp32-20220706版本,并且降低了JTAG的时钟,但都没有效果,新的错误信息如下:
Open On-Chip Debugger v0.11.0-esp32-20220706 (2022-07-06-15:48)
Flashing C:/Espressif/frameworks/esp-idf-v4.4/workspace/BMS76952/build/bootloader/bootloader.bin at 0x0
Info : esp_usb_jtag: serial (84:F7:03:BC:EF:3C)
Info : datacount=2 progbufsize=16
Info : Reset cause (3) - (Software core reset)
Info : [esp32c3] Found 8 triggers
-1
ESP_Gargamel
Postby ESP_Gargamel » Wed Aug 10, 2022 1:32 am
我没有 windows,也没用过 windows 下的 eclipse IDE。暂时不确认这是 eclipse 带进来的问题,还是 openocd 的问题。
请直接用 openocd 命令烧录试一下,可以使用 blink 示例,或者烧你自己工程的 bootloader.bin,注意路径和烧写起始地址:
openocd -f board/esp32c3-builtin.cfg -c "program_esp build/blink.bin 0x10000 verify exit"
我这边在 linux 下用这个命令烧录没有问题,你那边如果这个烧录没有问题的话,可以把 eclipse 里自动烧录的功能关掉,调试前先用 idf.py flash 或以上命令烧录。
sxliujin
Postby sxliujin » Wed Aug 10, 2022 11:46 am
openocd -f board/esp32c3-builtin.cfg -c "program_esp build/BMS76952_4S.bin 0x10000 verify exit"
您好,通过shell命令行,错误也是相同的。
ESP_Gargamel
Postby ESP_Gargamel » Tue Aug 16, 2022 9:57 am
试了下 Windows,也没遇到问题。
PS E:\workspace\esp-idf-v4.4.2\examples\get-started\blink> openocd -f board/esp32c3-builtin.cfg -c "program_esp build/blink.bin 0x10000 verify exit"
Open On-Chip Debugger  v0.11.0-esp32-20220411 (2022-04-11-08:48)
Info : esp_usb_jtag: serial (7C:DF:A1:59:77:B8)
Info : Flash mapping 0: 0x10020 -> 0x3c020020, 31 KB
Info : Flash mapping 1: 0x20020 -> 0x42000020, 81 KB
Info : PROF: Data transferred in 32109.3 ms @ 5.23212 KB/s
** Verified OK **
你再用
espefuse.py -p /dev/ttyUSB0 summary
读取一下 efuse 看看,串口改成你自己的。另外,换 Linux 试试,换个板子试试,看看情况。
sxliujin
Postby sxliujin » Wed Aug 17, 2022 12:04 pm
eFuse的结果如下
PS C:\Espressif\frameworks\esp-idf-v4.4> espefuse.py -p COM6 summary
Connecting...
espefuse.py v3.2-dev
EFUSE_NAME (Block) Description = [Meaningful Value] [Readable/Writeable] (Hex Value)
Config fuses:
DIS_ICACHE (BLOCK0) Disables ICache = False R/W (0b0)
DIS_DOWNLOAD_ICACHE (BLOCK0) Disables Icache when SoC is in Download mode = False R/W (0b0)
DIS_FORCE_DOWNLOAD (BLOCK0) Disables forcing chip into Download mode = False R/W (0b0)
DIS_CAN (BLOCK0) Disables the TWAI Controller hardware = False R/W (0b0)
VDD_SPI_AS_GPIO (BLOCK0) Set this bit to vdd spi pin function as gpio = False R/W (0b0)
BTLC_GPIO_ENABLE (BLOCK0) Enable btlc gpio = 0 R/W (0b00)
POWERGLITCH_EN (BLOCK0) Set this bit to enable power glitch function = False R/W (0b0)
POWER_GLITCH_DSENSE (BLOCK0) Sample delay configuration of power glitch = 0 R/W (0b00)
DIS_LEGACY_SPI_BOOT (BLOCK0) Disables Legacy SPI boot mode = False R/W (0b0)
UART_PRINT_CHANNEL (BLOCK0) Selects the default UART for printing boot msg = UART0 R/W (0b0)
UART_PRINT_CONTROL (BLOCK0) Sets the default UART boot message output mode = Enabled R/W (0b00)
FORCE_SEND_RESUME (BLOCK0) Force ROM code to send a resume command during SPI = False R/W (0b0)
bootduring SPI boot
BLOCK_USR_DATA (BLOCK3) User data
= 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W
Efuse fuses:
WR_DIS (BLOCK0) Disables programming of individual eFuses = 0 R/W (0x00000000)
RD_DIS (BLOCK0) Disables software reading from BLOCK4-10 = 0 R/W (0b0000000)
Flash Config fuses:
FLASH_TPUW (BLOCK0) Configures flash startup delay after SoC power-up, = 0 R/W (0x0)
unit is (ms/2). When the value is 15, delay is 7.
5 ms
FLASH_ECC_MODE (BLOCK0) Set this bit to set flsah ecc mode.
= flash ecc 16to18 byte mode R/W (0b0)
FLASH_TYPE (BLOCK0) Selects SPI flash type = 4 data lines R/W (0b0)
FLASH_PAGE_SIZE (BLOCK0) Flash page size = 0 R/W (0b00)
FLASH_ECC_EN (BLOCK0) Enable ECC for flash boot = False R/W (0b0)
Identity fuses:
SECURE_VERSION (BLOCK0) Secure version (used by ESP-IDF anti-rollback feat = 0 R/W (0x0000)
ure)
MAC (BLOCK1) Factory MAC Address
= 84:f7:03:bc:ef:3c (OK) R/W
WAFER_VERSION (BLOCK1) WAFER version = 3 R/W (0b011)
PKG_VERSION (BLOCK1) Package version = ESP32-C3 R/W (0b000)
BLOCK1_VERSION (BLOCK1) BLOCK1 efuse version = 4 R/W (0b100)
OPTIONAL_UNIQUE_ID (BLOCK2) Optional unique 128-bit ID
= 8b 61 38 d6 ed 17 6e d7 c8 1c 33 c1 bd b6 90 79 R/W
BLOCK2_VERSION (BLOCK2) Version of BLOCK2 = No calibration R/W (0b000)
CUSTOM_MAC (BLOCK3) Custom MAC Address
= 00:00:00:00:00:00 (OK) R/W
Jtag Config fuses:
JTAG_SEL_ENABLE (BLOCK0) Set this bit to enable selection between usb_to_jt = False R/W (0b0)
ag and pad_to_jtag through strapping gpio10 when b
oth reg_dis_usb_jtag and reg_dis_pad_jtag are equa
l to 0.
SOFT_DIS_JTAG (BLOCK0) Software disables JTAG. When software disabled, JT = 0 R/W (0b000)
AG can be activated temporarily by HMAC peripheral
DIS_PAD_JTAG (BLOCK0) Permanently disable JTAG access via pads. USB JTAG = False R/W (0b0)
is controlled separately.
Security fuses:
DIS_DOWNLOAD_MANUAL_ENCRYPT (BLOCK0) Disables flash encryption when in download boot mo = False R/W (0b0)
des
SPI_BOOT_CRYPT_CNT (BLOCK0) Enables encryption and decryption, when an SPI boo = Disable R/W (0b000)
t mode is set. Enabled when 1 or 3 bits are set,di
sabled otherwise
SECURE_BOOT_KEY_REVOKE0 (BLOCK0) If set, revokes use of secure boot key digest 0 = False R/W (0b0)
SECURE_BOOT_KEY_REVOKE1 (BLOCK0) If set, revokes use of secure boot key digest 1 = False R/W (0b0)
SECURE_BOOT_KEY_REVOKE2 (BLOCK0) If set, revokes use of secure boot key digest 2 = False R/W (0b0)
KEY_PURPOSE_0 (BLOCK0) KEY0 purpose = USER R/W (0x0)
KEY_PURPOSE_1 (BLOCK0) KEY1 purpose = USER R/W (0x0)
KEY_PURPOSE_2 (BLOCK0) KEY2 purpose = USER R/W (0x0)
KEY_PURPOSE_3 (BLOCK0) KEY3 purpose = USER R/W (0x0)
KEY_PURPOSE_4 (BLOCK0) KEY4 purpose = USER R/W (0x0)
KEY_PURPOSE_5 (BLOCK0) KEY5 purpose = USER R/W (0x0)
SECURE_BOOT_EN (BLOCK0) Enables secure boot = False R/W (0b0)
SECURE_BOOT_AGGRESSIVE_REVOKE (BLOCK0) Enables aggressive secure boot key revocation mode = False R/W (0b0)
DIS_DOWNLOAD_MODE (BLOCK0) Disables all Download boot modes = False R/W (0b0)
ENABLE_SECURITY_DOWNLOAD (BLOCK0) Enables secure UART download mode (read/write flas = False R/W (0b0)
h only)
BLOCK_KEY0 (BLOCK4)
Purpose: USER
Encryption key0 or user data
BLOCK_KEY1 (BLOCK5)
Purpose: USER
Encryption key1 or user data
BLOCK_KEY2 (BLOCK6)
Purpose: USER
Encryption key2 or user data
BLOCK_KEY3 (BLOCK7)
Purpose: USER
Encryption key3 or user data
BLOCK_KEY4 (BLOCK8)
Purpose: USER
Encryption key4 or user data
BLOCK_KEY5 (BLOCK9)
Purpose: USER
Encryption key5 or user data
BLOCK_SYS_DATA2 (BLOCK10) System data (part 2)
Spi_Pad_Config fuses:
SPI_PAD_CONFIG_CLK (BLOCK1) SPI CLK pad = 0 R/W (0b000000)
SPI_PAD_CONFIG_Q (BLOCK1) SPI Q (D1) pad = 0 R/W (0b000000)
SPI_PAD_CONFIG_D (BLOCK1) SPI D (D0) pad = 0 R/W (0b000000)
SPI_PAD_CONFIG_CS (BLOCK1) SPI CS pad = 0 R/W (0b000000)
SPI_PAD_CONFIG_HD (BLOCK1) SPI HD (D3) pad = 0 R/W (0b000000)
SPI_PAD_CONFIG_WP (BLOCK1) SPI WP (D2) pad = 0 R/W (0b000000)
SPI_PAD_CONFIG_DQS (BLOCK1) SPI DQS pad = 0 R/W (0b000000)
SPI_PAD_CONFIG_D4 (BLOCK1) SPI D4 pad = 0 R/W (0b000000)
SPI_PAD_CONFIG_D5 (BLOCK1) SPI D5 pad = 0 R/W (0b000000)
SPI_PAD_CONFIG_D6 (BLOCK1) SPI D6 pad = 0 R/W (0b000000)
SPI_PAD_CONFIG_D7 (BLOCK1) SPI D7 pad = 0 R/W (0b000000)
Usb Config fuses:
DIS_USB_JTAG (BLOCK0) Disables USB JTAG. JTAG access via pads is control = False R/W (0b0)
led separately
DIS_USB_DEVICE (BLOCK0) Disables USB DEVICE = False R/W (0b0)
DIS_USB (BLOCK0) Disables the USB OTG hardware = False R/W (0b0)
USB_EXCHG_PINS (BLOCK0) Exchanges USB D+ and D- pins = False R/W (0b0)
DIS_USB_DOWNLOAD_MODE (BLOCK0) Disables use of USB in UART download boot mode = False R/W (0b0)
Vdd_Spi Config fuses:
PIN_POWER_SELECTION (BLOCK0) GPIO33-GPIO37 power supply selection in ROM code = VDD3P3_CPU R/W (0b0)
Wdt Config fuses:
WDT_DELAY_SEL (BLOCK0) Selects RTC WDT timeout threshold at startup = False R/W (0b0)
efuse内部关于JTAG的那一项 我查是说用4线TMS TCK TDO TDI 模式才需要熔断,builtin-JTAG不需要操作
ESP_Gargamel
Postby ESP_Gargamel » Thu Aug 18, 2022 6:44 am
efuse 没有问题。
你先用 idf.py flash 把程序烧录一次,然后再试一下。
试了把 flash 都擦掉,然后烧录:
$ openocd -f board/esp32c3-builtin.cfg -c "program_esp build/blink.bin 0x10000 verify exit"
Error: Failed to get flash maps (4294967290)!
Info : PROF: Data transferred in 2452.89 ms @ 66.86 KB/s
** Verified OK **
前面会有 error,但还是可以 detect 到 flash。
sxliujin
Postby sxliujin » Fri Aug 26, 2022 1:35 pm
您好,按您的方式操作后发现还是不能挂JTAG,但是现在报错变了
Flashing C:/Espressif/frameworks/esp-idf-v4.4/workspace/BMS76952_13S/build/bootloader/bootloader.bin at 0x0
Info : Flash mapping 0: 0x10020 -> 0x3c0b0020, 153 KB
Info : Flash mapping 1: 0x40020 -> 0x42000020, 685 KB
Info : PROF: Erased 20480 bytes in 475.731 ms
Info : PROF: Data transferred in 268.801 ms @ 74.4045 KB/s
Info : PROF: Wrote 20480 bytes in 728.183 ms (data transfer time included)
** Programming Finished in 2063 ms **
Info : PROF: Flash verified in 243.105 ms
** Verify OK **
** Flashing done for bootloader/bootloader.bin in 2308 ms **
Flashing C:/Espressif/frameworks/esp-idf-v4.4/workspace/BMS76952_13S/build/BMS76952_13S.bin at 0x10000
Info : PROF: Erased 471040 bytes in 3024.83 ms
Info : PROF: Data transferred in 5780.03 ms @ 79.5844 KB/s
Info : PROF: Wrote 471040 bytes in 6329.12 ms (data transfer time included)
** Programming Finished in 9696 ms **
Info : PROF: Flash verified in 463.457 ms
** Verify OK **
** Flashing done for BMS76952_13S.bin in 10166 ms **
Flashing C:/Espressif/frameworks/esp-idf-v4.4/workspace/BMS76952_13S/build/partition_table/partition-table.bin at 0x8000
Info : PROF: Erased 4096 bytes in 292.733 ms
Info : PROF: Data transferred in 77.921 ms @ 51.334 KB/s
Info : PROF: Wrote 4096 bytes in 491.515 ms (data transfer time included)
** Programming Finished in 1117 ms **
Info : PROF: Flash verified in 231.708 ms
** Verify OK **
** Flashing done for partition_table/partition-table.bin in 1352 ms **
** Total programming time 13829 ms **
0
Info : Flash mapping 0: 0x10020 -> 0x3c060020, 67 KB
Info : Flash mapping 1: 0x30020 -> 0x42000020, 328 KB
Info : Using flash bank 'esp32c3.irom' size 332 KB
Warn : Prefer GDB command "target extended-remote :3333" instead of "target remote :3333"
Error: FreeRTOS maximum used priority is unreasonably big, not proceeding: 133
Users browsing this forum: No registered users and 23 guests
