Hi
We have designed a board using ESP32-C3FN4
We are not able to detect the chip. We have provided EPSON 40MHZ crystal [FA-238].
The hardware guide for ESP32 C3 mentions that we have to choose a component in series with XTAL P pin, but does not recommend any value.
Also there is a 499ohm in series with UOTXD in the ref schematic.
Need help of experts to solve this.
Hardware connection to the ESP32 C3FN4
ESP UART -- FTDI UART
U0TXD - RX
U0RXD - TX
GND - GND
IO0 - GPIO9
RST - EN
Best Regards
ESP32 C3FN4 not detecting
- RESET, program pins on UART.jpg (97.66 KiB) Viewed 1509 times
- ESP32 C3FN4 not detecting.jpg (193.03 KiB) Viewed 1509 times
Re: ESP32 C3FN4 not detecting
- What do you use as a 3.3V power source?
- Can you confirm the reset signal is OK? (Pulled low at startup, then high afterwards)
- Does your 40MHz crystal oscillate? Measure it with an oscilloscope, you should see a 40MHz low-ish amplitude sine on one of the pins.
- Do you see bootup chatter on the Tx0 pin when you reset the ESP?
Hi
I use a LDO as a power source. 3.3V is stable
I think the issue is with GPIO8 and GPIO2 not be pulled up with 10K to 3.3V, as i have connected it to an LED.
As per ESP32 C3 TRM, page 182, Table 7-2, GPIO8 and GPIO2 states should be high when the device is booting out of reset.
Will try this assumption and keep you posted.
BR
shastrinvs
BR
shastrinvs
Users browsing this forum: No registered users and 46 guests
