SD卡例程-pipeline_play_sdcard_music
flyingbear1711
Postby flyingbear1711 » Tue Jul 26, 2022 8:20 am
在 LYRAT_V4_3 开发板上,运行pipeline_play_sdcard_music例程,一运行就报一下错误,烦请乐鑫工程师瞧一下是啥问题呗?官方的开发板硬件应该没问题吧 :roll: :roll: :roll: :roll:
I (258) cpu_start: App cpu up.
I (285) cpu_start: Pro cpu start user code
I (285) cpu_start: cpu freq: 160000000
I (285) cpu_start: Application information:
I (289) cpu_start: Project name: play_sdcard_music
I (295) cpu_start: App version: v2.4-30-gc323b97-dirty
I (302) cpu_start: Compile time: Jul 26 2022 16:07:54
I (308) cpu_start: ELF file SHA256: 2556a07c93545cfe...
I (314) cpu_start: ESP-IDF: v4.4.1-dirty
I (319) heap_init: Initializing. RAM available for dynamic allocation:
I (326) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (332) heap_init: At 3FFB3050 len 0002CFB0 (179 KiB): DRAM
I (339) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (345) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (351) heap_init: At 4008FA00 len 00010600 (65 KiB): IRAM
I (359) spi_flash: detected chip: generic
I (362) spi_flash: flash io: dio
I (367) cpu_start: Starting scheduler on PRO CPU.
I (377) PLAY_SDCARD_MUSIC: [ 1 ] Mount sdcard
E (537) sdmmc_sd: sdmmc_init_sd_scr: send_scr (1) returned 0x107
E (537) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
E (537) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place.
E (547) PERIPH_SDCARD: mount sdcard error!
E (1707) sdmmc_sd: sdmmc_init_sd_scr: send_scr (1) returned 0x107
E (1707) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
E (1707) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place.
E (1717) PERIPH_SDCARD: mount sdcard error!
E (2707) sdmmc_sd: sdmmc_init_sd_scr: send_scr (1) returned 0x107
E (2707) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
E (2707) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place.
E (2717) PERIPH_SDCARD: mount sdcard error!
flyingbear1711
Re: SD卡例程-pipeline_play_sdcard_music
Postby flyingbear1711 » Sat Jul 30, 2022 2:36 am
问题已解决,官方开发板的sd卡座虚焊了。。。
ESP_HengYC
Postby ESP_HengYC » Wed Aug 03, 2022 3:08 am
是的, 这个是 sdcard 初始化失败的错误。
Users browsing this forum: No registered users and 14 guests
