I have a question while I am currently developing own custom ESP32-s3 based design.
The question is about how to manage power requirement for the board and external RGB LED strips connected via the board.
The thing is that the LED strip may require currents upto five to seven Ampere, while the board only requires less than 1A.
On board I am using a 5V to 3.3V regulator chip to convert the voltage so that I can power the board via USB.
What about the LED strip? What are my options? I will need one GPIO for driving these strips and let's say I keep comman ground. What about power line which powers the main board on less current and LED strips with current more than 5Amps?
Question regarding custom PCB design for power management.
Re: Question regarding custom PCB design for power management.
for such a high current, I think you need a especial driver circuit or IC, not just use a GPIO.
What LED strip are you using? Addressable WS2812b?
Users browsing this forum: No registered users and 109 guests
