The correct order to call the functions is:
mdns_init
mdns_hostname_set
mdns_instance_name_set
mdns_service_add
When we call them like this:
mdns_init
mdns_service_add
mdns_hostname_set
The IDF crashes with a LoadProhibited. And it costs hours to find out the wrong order is the problem...
My opinion is, there should be an error message tops, but no crash.
mDNS crash when functions called in wrong order
ESP32 / ESP-IDF 5.1.3
Re: mDNS crash when functions called in wrong order
Minimum code example:
Typical output:
#include "esp_log.h"
#include "esp_wifi.h"
#include "nvs_flash.h"
#include "mdns.h"
static const char *TAG = "main";
void app_main(void) {
nvs_flash_init();
esp_netif_init();
esp_event_loop_create_default();
esp_netif_create_default_wifi_sta();
wifi_init_config_t wifi_init_config = WIFI_INIT_CONFIG_DEFAULT();
esp_wifi_init(&wifi_init_config);
esp_wifi_start();
esp_wifi_connect();
mdns_init();
mdns_service_add(NULL, "_http", "_tcp", 80, NULL, 0);
ESP_LOGI(TAG, "mdns_hostname_set...");
mdns_hostname_set("crashme");
I (00:00:02.451) main: mdns_hostname_set...
Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x40001277 PS : 0x00060c30 A0 : 0x800d65eb A1 : 0x3ffc7080
A2 : 0x00000000 A3 : 0x00000000 A4 : 0x00000001 A5 : 0x00000001
A6 : 0x3ffc5f00 A7 : 0x00000000 A8 : 0x00000001 A9 : 0x00000000
A10 : 0x00060c23 A11 : 0x00000000 A12 : 0x00000001 A13 : 0x00060c23
A14 : 0x00000003 A15 : 0x00060023 SAR : 0x0000000f EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000000 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff
Backtrace:0x40001274:0x3ffc70800x400d65e8:0x3ffc7090 0x400dbac8:0x3ffc70b0 0x400dbdf6:0x3ffc70f0 0x4008b87a:0x3ffc7120
0x400d65e8: _mdns_remap_self_service_hostname at C:/Users/***/esp/esp-idf/components/mdns/mdns.c:4226
0x400dbac8: _mdns_execute_action at C:/Users/***/esp/esp-idf/components/mdns/mdns.c:4307
0x400dbdf6: _mdns_service_task at C:/Users/***/esp/esp-idf/components/mdns/mdns.c:4596
0x4008b87a: vPortTaskWrapper at C:/Users/***/esp/esp-idf/components/freertos/port/xtensa/port.c:131
Thanks, I created an internal issue for this. Note that if it's all the same to you, next time we 'd prefer it if you create an issue on the ESP-IDF Github as that gets tracked automatically.
Thanks for reporting this problem (sorry for the delay & sorry for the inconvenience). I agree that mDNS API should be improved.
Although it's mentioned in the example:
https://github.com/espressif/esp-idf/bl ... .c#L41-L42
That if you want to advertize services it's required to configure hostname, we should not null dereference pointers and variables, but gracefully report errors. I've posted a PR fixing the issue here https://github.com/espressif/esp-protocols/pull/117
Users browsing this forum: Bing [Bot], Nanazhang and 68 guests
