Using the repl function, it will restart every time the serial port is opened
Use the USB Serial/JTAG Controller as the console output, configure the USB Serial/JTAG Controller as the repl port, every time you use the serial port assistant to open the serial port, you will see the device print the startup information once, but I can't find where to restart it. Help bosses!
Re: Using the repl function, it will restart every time the serial port is opened
How to understand this passage
- The behavior between an actual USB-to-serial bridge chip and the USB Serial/JTAG Controller is slightly different if the ESP-IDF application does not listen for incoming bytes. An USB-to-serial bridge chip will just send the bytes to a (not listening) chip, while the USB Serial/JTAG Controller will block until the application reads the bytes. This can lead to a non-responsive looking terminal program.
refer to
https://docs.espressif.com/projects/esp ... nsole.html
Users browsing this forum: No registered users and 72 guests
