Dear forum
Got an ESP8266 running measuring my Energy consumption and solar panels yield. Got it running for a few years already. Now and then, maybe twice a day, it reboots. This was not the case in the beginning it would run for days, even months. I'd like to investigate the cause of the error.
I cannot 'wait' for hours to watch this to occur and then read the serial output. Is there a way to store the reboot report so I can read that at my convenience?
An example of such a function is highly appreciated.
Thanks.
ESP8266 reboot report
Re: ESP8266 reboot report
ESP.getResetReason().c_str() will return a string with reason for last reset
rst_info *resetInfo;
resetInfo = ESP.getResetInfoPtr();
will give you access to the rst_info structure which has more detail
Check out https://www.esp8266.com/viewtopic.php?p=26862
From either of those you could store the data in a file if you have the filing system set up.
Thanks. I'll try that.
