Re: ESP32 ISA reference manual
Posted: Sat Aug 24, 2019 11:38 am
hi angus,ESP_Angus wrote: ↑Thu Aug 22, 2019 1:16 amHi rudi,
Do you mean xt-xcc (the Cadence/Tensilica compiler, not based on gcc)?rudi ;-) wrote: ↑Wed Aug 21, 2019 7:12 pmdo you know, is there a config file for LX6, LX7 for the xt-gcc ( LX106 ) and can we theoretical use the xt-gcc (lx106) with an LX6, LX7 config file or do we need a full new xt-gcc compiler for each ( Lx6, Lx7 ) ? for esp8266(lx106) i use parallel xt-gcc from cadence - so
In theory you need the compiler to match the CPU that you have, so esp8266/lx106 compiler is not suitable for ESP32 or ESP32-S2. In practice maybe the code will run (as ESP8266 CPU is mostly simpler than newer CPUs) but it won't use newer features, will use call0 ABI not windowed, etc - code will overall be less optimised.
yes u are right, i mean the XT-XCC compiler, ( typo finger crossed )
use older version (bin) xt-xcc version 8.0.1.1 (xcc-lib) xt-xcc version 8.0.1
but i use also the open src gcc compiler for 8266's
for each target we need then an own (lx106, Lx6, Lx7) compiler?
i thinked allways it is enough to have the target config file (lx106-params) / (lx***-params) for each and would be enough.
ok learned a part now from you
![Smile :)](./images/smilies/icon_e_smile.gif)
or I'm too relaxed on vacation and my brain is on reserve. / switched off.
so i know my next lession for this winter for deeper look in.
never stop going learing -
thank you
rudi
![Wink ;-)](./images/smilies/icon_e_wink.gif)
edit:
[Q]:
from read, ESP32 is LX6 core and ESP32S2 is LX7 (64 FLOP) core
we use/get then a different toolchain ( compiler ) for ESP32S2 ?
The toolchain tuple is xtensa-esp32s2-elf-, for example gcc for this target is named xtensa-esp32s2-elf-gcc.
right?
edit:
I think I've mixed apples and pears now.
the (cross) compiler build needs the config params
for the toolchain. I really thought now
this config params file is enough
to use with the END (cross) compiler that was formed.
I'm happy to be on vacation - so much mixed up in my head
hope I come back in order
(( but can not keep his fingers off the computer just turn it off
but the knowledge about compiler construction itself is intensified in the winter,
I have since discovered a few gaps in knowledge with me, to which I had no answer.
I have to change that and improve it
thanks angus !!
