I put the same question in the IDF section, so perhaps here it is more correct. In any case, I can't find in the datasheet the DNL and INL of the esp32-C6. Is it the same of esp32-S3, or is it different?
Also, does the Esp32-c6 include the touch peripheral?
esp32-c6 adc specification and touch
Re: esp32-c6 adc specification and touch
Unfortunately, the INL and DNL of ADC are not mentioned in the datasheet of ESP32-C6.
As far as I can see in the block diagrams and description, ESP32-C6 has no built-in touch sensor.
Is there a way to ask the DNL and INL of the device?
It's not known yet; we need time to characterize the ADC specs properly.
Hi there,
These parameters will be released in ESP32-C6 Datasheet v1.0 (the official release for the mass produced chip) hopefully at the end of this month.
For your reference, attached are some preliminary results:
Please note that these data might be different in the official release. Thank you!
- esp32-c6-adc.png (55.91 KiB) Viewed 31968 times
do you also have the sample and hold capacitor value, the multiplexer resistance switch value and the acquisition time?
thank you!
thank you!
Users browsing this forum: No registered users and 10 guests
