esp32-c3 新建蓝牙服务问题
Moderator: ESP_ZT
Robert-qiao
esp32-c3 新建蓝牙服务问题
Postby Robert-qiao » Sun Aug 04, 2024 8:16 am
版本环境:ESP-IDF V5.2.2
根据例程新建一个服务后,增加第二个服务时,出现附件1问题,esp_log.h出现问题,当切换到V4.4.8版本时,编译无问题。
以下为源代码:
 * SPDX-FileCopyrightText: 2021-2023 Espressif Systems (Shanghai) CO LTD
 * SPDX-License-Identifier: Unlicense OR CC0-1.0
* This demo showcases creating a GATT database using a predefined attribute table.
* It acts as a GATT server and can send adv data, be connected by client.
* Run the gatt_client demo, the client demo will automatically connect to the gatt_server_service_table demo.
* Client demo will enable GATT server's notify after connection. The two devices will then exchange
* data.
#include <stdio.h>
#include "User_BLE.h"
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "esp_bt.h"
#include "esp_gap_ble_api.h"
#include "esp_gatts_api.h"
#include "esp_bt_main.h"
#include "esp_gatt_common_api.h"
#define GATTS_CELEX "GATTS_CELEX"
#define PROFILE_NUM                2
#define PROFILE_A_APP_IDX             0
#define PROFILE_B_APP_IDX             1
#define PROFILE_C_APP_ID             2
#define ESP_APP_ID                  0x55
#define SAMPLE_DEVICE_NAME          "ESP_GATTS_DEMO"
#define SVC_INST_ID                 0
esp_gatt_char_prop_t a_property = 0;
char *TEST_DEVICE_NAME = "IMS6-D2Keeptime"; // 蓝牙设备名称修改
/* The max length of characteristic value. When the GATT client performs a write or prepare write operation,
*  the data length must be less than GATTS_DEMO_CHAR_VAL_LEN_MAX.
#define GATTS_DEMO_CHAR_VAL_LEN_MAX 500
#define PREPARE_BUF_MAX_SIZE        1024
#define CHAR_DECLARATION_SIZE       (sizeof(uint8_t))
#define ADV_CONFIG_FLAG             (1 << 0)
#define SCAN_RSP_CONFIG_FLAG        (1 << 1)
static uint8_t adv_config_done       = 0;
uint16_t heart_rate_handle_table[HRS_IDX_NB];
uint16_t heart_2rate_handle_table[HRS2_IDX_NB];
typedef struct {
    uint8_t                 *prepare_buf;
    int                     prepare_len;
} prepare_type_env_t;
static prepare_type_env_t prepare_write_env;
static prepare_type_env_t a_prepare_write_env;
static prepare_type_env_t b_prepare_write_env;
void example_write_event_env(esp_gatt_if_t gatts_if, prepare_type_env_t *prepare_write_env, esp_ble_gatts_cb_param_t *param);
//#define CONFIG_SET_RAW_ADV_DATA
#ifdef CONFIG_SET_RAW_ADV_DATA
static uint8_t raw_adv_data[] = {
        /* flags */
        0x02, 0x01, 0x06,
        /* tx power*/
        0x02, 0x0a, 0xeb,
        /* service uuid */
        0x03, 0x03, 0xFF, 0x00,
        /* device name */
        0x0f, 0x09, 'E', 'S', 'P', '_', 'G', 'A', 'T', 'T', 'S', '_', 'D','E', 'M', 'O'
static uint8_t raw_scan_rsp_data[] = {
        /* flags */
        0x02, 0x01, 0x06,
        /* tx power */
        0x02, 0x0a, 0xeb,
        /* service uuid */
        0x03, 0x03, 0xFF,0x00
#else
static uint8_t service_uuid[16] = {
    /* LSB <--------------------------------------------------------------------------------> MSB */
    //first uuid, 16bit, [12],[13] is the value
    //0xfb, 0x34, 0x9b, 0x5f, 0x80, 0x00, 0x00, 0x80, 0x00, 0x10, 0x00, 0x00, 0xFF, 0x00, 0x00, 0x00,
    0x9d,
    0xca,
    0xdc,
    0x24,
    0x0e,
    0xe5,
    0xa9,
    0xe0,
    0x93,
    0xf3,
    0xa3,
    0xb5,
    0x03,
    0x00,
    0x40,
    0x6e,
uint8_t char1_str[] = {0x11, 0x22, 0x33};
esp_attr_value_t gatts_demo_char1_val =
        .attr_max_len = GATTS_DEMO_CHAR_VAL_LEN_MAX,
        .attr_len = sizeof(char1_str),
        .attr_value = char1_str,
/* The length of adv data must be less than 31 bytes */
static esp_ble_adv_data_t adv_data = {
    .set_scan_rsp        = false,
    .include_name        = true,
    .include_txpower     = true,
    .min_interval        = 0x0006, //slave connection min interval, Time = min_interval * 1.25 msec
    .max_interval        = 0x0010, //slave connection max interval, Time = max_interval * 1.25 msec
    .appearance          = 0x00,
    .manufacturer_len    = 0,    //TEST_MANUFACTURER_DATA_LEN,
    .p_manufacturer_data = NULL, //test_manufacturer,
    .service_data_len    = 0,
    .p_service_data      = NULL,
    .service_uuid_len    = sizeof(service_uuid),
    .p_service_uuid      = service_uuid,
    .flag = (ESP_BLE_ADV_FLAG_GEN_DISC | ESP_BLE_ADV_FLAG_BREDR_NOT_SPT),
// scan response data
static esp_ble_adv_data_t scan_rsp_data = {
    .set_scan_rsp        = true,
    .appearance          = 0x00,
    .p_manufacturer_data = NULL, //&test_manufacturer[0],
#endif /* CONFIG_SET_RAW_ADV_DATA */
static esp_ble_adv_params_t adv_params = {
    .adv_int_min         = 0x20,
    .adv_int_max         = 0x40,
    .adv_type            = ADV_TYPE_IND,
    .own_addr_type       = BLE_ADDR_TYPE_PUBLIC,
    .channel_map         = ADV_CHNL_ALL,
    .adv_filter_policy   = ADV_FILTER_ALLOW_SCAN_ANY_CON_ANY,
struct gatts_profile_inst {
    esp_gatts_cb_t gatts_cb;
    uint16_t gatts_if;
    uint16_t app_id;
    uint16_t conn_id;
    uint16_t service_handle;
    esp_gatt_srvc_id_t service_id;
    uint16_t char_handle;
    esp_bt_uuid_t char_uuid;
    esp_gatt_perm_t perm;
    esp_gatt_char_prop_t property;
    uint16_t descr_handle;
    esp_bt_uuid_t descr_uuid;
static void gatts_profile_A_event_handler(esp_gatts_cb_event_t event,
					esp_gatt_if_t gatts_if, esp_ble_gatts_cb_param_t *param);
static void gatts_profile_B_event_handler(esp_gatts_cb_event_t event,
static void gatts_profile_C_event_handler(esp_gatts_cb_event_t event,
/* One gatt-based profile one app_id and one gatts_if, this array will store the gatts_if returned by ESP_GATTS_REG_EVT */
static struct gatts_profile_inst heart_rate_profile_tab[PROFILE_NUM] = {
    [PROFILE_A_APP_IDX] = {
        .gatts_cb = gatts_profile_A_event_handler,
        .gatts_if = ESP_GATT_IF_NONE,       /* Not get the gatt_if, so initial is ESP_GATT_IF_NONE */
    [PROFILE_B_APP_IDX] = {
        .gatts_cb = gatts_profile_B_event_handler, /* This demo does not implement, similar as profile A */
    // [PROFILE_C_APP_ID] = {
    //     .gatts_cb = gatts_profile_C_event_handler, /* This demo does not implement, similar as profile A */
    //     .gatts_if = ESP_GATT_IF_NONE,            /* Not get the gatt_if, so initial is ESP_GATT_IF_NONE */
/* Service */
static const uint16_t primary_service_uuid         = ESP_GATT_UUID_PRI_SERVICE;
static const uint16_t character_declaration_uuid   = ESP_GATT_UUID_CHAR_DECLARE;
static const uint16_t character_client_config_uuid = ESP_GATT_UUID_CHAR_CLIENT_CONFIG;
static const uint8_t char_prop_read                =  ESP_GATT_CHAR_PROP_BIT_READ;
static const uint8_t char_prop_write               = ESP_GATT_CHAR_PROP_BIT_WRITE;
// static const uint8_t char_prop_read_write_notify   = ESP_GATT_CHAR_PROP_BIT_WRITE | ESP_GATT_CHAR_PROP_BIT_READ | ESP_GATT_CHAR_PROP_BIT_NOTIFY;
static const uint8_t heart_measurement_ccc[2]      = {0x00, 0x00};
static const uint8_t char_value[4]                 = {0x11, 0x22, 0x33, 0x44};
// service UUID
static const uint8_t  GATTS_SERVICE_UUID_TEST[16]  = { 0xfb, 0x34, 0x9b, 0x5f, 0x80, 0x00, 0x00, 0x80, 0x00, 0x10, 0x00, 0x00, 0xf0, 0xff, 0x00, 0x00};
static const uint8_t  GATTS_CHAR_UUID_TEST_A[16]  = {  0xfb, 0x34, 0x9b, 0x5f, 0x80, 0x00, 0x00, 0x80, 0x00, 0x10, 0x00, 0x00, 0xf2, 0xff, 0x00, 0x00};
static const uint8_t  GATTS_CHAR_UUID_TEST_B[16]  = { 0xfb, 0x34, 0x9b, 0x5f, 0x80, 0x00, 0x00, 0x80, 0x00, 0x10, 0x00, 0x00, 0xf1, 0xff, 0x00, 0x00};
static const uint8_t  GATTS_CHAR_UUID_TEST_C[16]  = {  0xfb, 0x34, 0x9b, 0x5f, 0x80, 0x00, 0x00, 0x80, 0x00, 0x10, 0x00, 0x00, 0xfe, 0xff, 0x00, 0x00};
static const uint8_t char_prop_notify = ESP_GATT_CHAR_PROP_BIT_NOTIFY;
/* Full Database Description - Used to add attributes into the database */
static const esp_gatts_attr_db_t gatt_db[HRS_IDX_NB] =
           // Service Declaration
        [IDX_SVC] =
            {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&primary_service_uuid, ESP_GATT_PERM_READ,
            sizeof(GATTS_SERVICE_UUID_TEST), sizeof(GATTS_SERVICE_UUID_TEST), (uint8_t *)&GATTS_SERVICE_UUID_TEST}},
        /* Characteristic Declaration */
        [IDX_CHAR_A] =
            {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&character_declaration_uuid, ESP_GATT_PERM_READ,
            CHAR_DECLARATION_SIZE, CHAR_DECLARATION_SIZE, (uint8_t *)&char_prop_write}},
        /* Characteristic Value */
        [IDX_CHAR_VAL_A] =
            {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_128, (uint8_t *)&GATTS_CHAR_UUID_TEST_A, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
             GATTS_DEMO_CHAR_VAL_LEN_MAX, sizeof(char_value), (uint8_t *)char_value}},
        /* Client Characteristic Configuration Descriptor */
        [IDX_CHAR_CFG_A] =
            {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&character_client_config_uuid, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
            sizeof(uint16_t), sizeof(heart_measurement_ccc), (uint8_t *)heart_measurement_ccc}},
        [IDX_CHAR_B] =
            CHAR_DECLARATION_SIZE, CHAR_DECLARATION_SIZE, (uint8_t *)&char_prop_notify}},
        [IDX_CHAR_VAL_B] =
            {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_128, (uint8_t *)&GATTS_CHAR_UUID_TEST_B, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
        [IDX_CHAR_CFG_B] =
        [IDX_CHAR_C] =
            CHAR_DECLARATION_SIZE, CHAR_DECLARATION_SIZE, (uint8_t *)&char_prop_read}},
        [IDX_CHAR_VAL_C] =
            {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&GATTS_CHAR_UUID_TEST_C, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
// service 2
static const uint8_t  GATTS_SERVICE_UUID_Two[16]  = { 0xfb, 0x34, 0x9b, 0x5f, 0x80, 0x00, 0x00, 0x80, 0x00, 0x10, 0x00, 0x00, 0xf3, 0xff, 0x00, 0x00};
static const uint8_t  GATTS_CHAR_UUID_Two_A[16]  = {  0xfb, 0x34, 0x9b, 0x5f, 0x80, 0x00, 0x00, 0x80, 0x00, 0x10, 0x00, 0x00, 0xf5, 0xff, 0x00, 0x00};
static const uint8_t  GATTS_CHAR_UUID_Two_B[16]  = { 0xfb, 0x34, 0x9b, 0x5f, 0x80, 0x00, 0x00, 0x80, 0x00, 0x10, 0x00, 0x00, 0xf4, 0xff, 0x00, 0x00};
static const uint8_t  GATTS_CHAR_UUID_Two_C[16]  = {  0xfb, 0x34, 0x9b, 0x5f, 0x80, 0x00, 0x00, 0x80, 0x00, 0x10, 0x00, 0x00, 0xf6, 0xff, 0x00, 0x00};
const esp_gatts_attr_db_t gatt2_db[HRS2_IDX_NB] =
        [IDX2_SVC] =
            {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&primary_service_uuid, ESP_GATT_PERM_READ, sizeof(GATTS_SERVICE_UUID_Two), sizeof(GATTS_SERVICE_UUID_Two), (uint8_t *)&GATTS_SERVICE_UUID_Two}},
        [IDX2_CHAR_A] =
            {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&character_declaration_uuid, ESP_GATT_PERM_READ, CHAR_DECLARATION_SIZE, CHAR_DECLARATION_SIZE, (uint8_t *)&char_prop_write}},
        [IDX2_CHAR_VAL_A] =
            {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_128, (uint8_t *)&GATTS_CHAR_UUID_Two_A, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE, GATTS_DEMO_CHAR_VAL_LEN_MAX, sizeof(char_value), (uint8_t *)char_value}},
        [IDX2_CHAR_CFG_A] =
            {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&character_client_config_uuid, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE, sizeof(uint16_t), sizeof(heart_measurement_ccc), (uint8_t *)heart_measurement_ccc}},
        [IDX2_CHAR_B] =
            {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&character_declaration_uuid, ESP_GATT_PERM_READ, CHAR_DECLARATION_SIZE, CHAR_DECLARATION_SIZE, (uint8_t *)&char_prop_notify}},
        [IDX2_CHAR_VAL_B] =
            {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_128, (uint8_t *)&GATTS_CHAR_UUID_Two_B, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE, GATTS_DEMO_CHAR_VAL_LEN_MAX, sizeof(char_value), (uint8_t *)char_value}},
        [IDX2_CHAR_CFG_B] =
        [IDX2_CHAR_C] =
            {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&character_declaration_uuid, ESP_GATT_PERM_READ, CHAR_DECLARATION_SIZE, CHAR_DECLARATION_SIZE, (uint8_t *)&char_prop_read}},
        [IDX2_CHAR_VAL_C] =
            {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&GATTS_CHAR_UUID_Two_C, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE, GATTS_DEMO_CHAR_VAL_LEN_MAX, sizeof(char_value), (uint8_t *)char_value}},
static void gap_event_handler(esp_gap_ble_cb_event_t event, esp_ble_gap_cb_param_t *param)
    switch (event) {
        case ESP_GAP_BLE_ADV_DATA_RAW_SET_COMPLETE_EVT:
            adv_config_done &= (~ADV_CONFIG_FLAG);
            if (adv_config_done == 0){
                esp_ble_gap_start_advertising(&adv_params);
        case ESP_GAP_BLE_SCAN_RSP_DATA_RAW_SET_COMPLETE_EVT:
            adv_config_done &= (~SCAN_RSP_CONFIG_FLAG);
    #else
        case ESP_GAP_BLE_ADV_DATA_SET_COMPLETE_EVT:
        case ESP_GAP_BLE_SCAN_RSP_DATA_SET_COMPLETE_EVT:
    #endif
        case ESP_GAP_BLE_ADV_START_COMPLETE_EVT:
            /* advertising start complete event to indicate advertising start successfully or failed */
            if (param->adv_start_cmpl.status != ESP_BT_STATUS_SUCCESS) {
                ESP_LOGE(GATTS_CELEX, "advertising start failed");
            }else{
                ESP_LOGI(GATTS_CELEX, "advertising start successfully");
        case ESP_GAP_BLE_ADV_STOP_COMPLETE_EVT:
            if (param->adv_stop_cmpl.status != ESP_BT_STATUS_SUCCESS) {
                ESP_LOGE(GATTS_CELEX, "Advertising stop failed");
            else {
                ESP_LOGI(GATTS_CELEX, "Stop adv successfully");
        case ESP_GAP_BLE_UPDATE_CONN_PARAMS_EVT:
            ESP_LOGI(GATTS_CELEX, "update connection params status = %d, min_int = %d, max_int = %d,conn_int = %d,latency = %d, timeout = %d",
                  param->update_conn_params.status,
                  param->update_conn_params.min_int,
                  param->update_conn_params.max_int,
                  param->update_conn_params.conn_int,
                  param->update_conn_params.latency,
                  param->update_conn_params.timeout);
        default:
void example_prepare_write_event_env(esp_gatt_if_t gatts_if, prepare_type_env_t *prepare_write_env, esp_ble_gatts_cb_param_t *param)
    ESP_LOGI(GATTS_CELEX, "prepare write, handle = %d, value len = %d", param->write.handle, param->write.len);
    esp_gatt_status_t status = ESP_GATT_OK;
    if (param->write.offset > PREPARE_BUF_MAX_SIZE) {
        status = ESP_GATT_INVALID_OFFSET;
    } else if ((param->write.offset + param->write.len) > PREPARE_BUF_MAX_SIZE) {
        status = ESP_GATT_INVALID_ATTR_LEN;
    if (status == ESP_GATT_OK && prepare_write_env->prepare_buf == NULL) {
        prepare_write_env->prepare_buf = (uint8_t *)malloc(PREPARE_BUF_MAX_SIZE * sizeof(uint8_t));
        prepare_write_env->prepare_len = 0;
        if (prepare_write_env->prepare_buf == NULL) {
            ESP_LOGE(GATTS_CELEX, "%s, Gatt_server prep no mem", __func__);
            status = ESP_GATT_NO_RESOURCES;
    /*send response when param->write.need_rsp is true */
    if (param->write.need_rsp){
        esp_gatt_rsp_t *gatt_rsp = (esp_gatt_rsp_t *)malloc(sizeof(esp_gatt_rsp_t));
        if (gatt_rsp != NULL){
            gatt_rsp->attr_value.len = param->write.len;
            gatt_rsp->attr_value.handle = param->write.handle;
            gatt_rsp->attr_value.offset = param->write.offset;
            gatt_rsp->attr_value.auth_req = ESP_GATT_AUTH_REQ_NONE;
            memcpy(gatt_rsp->attr_value.value, param->write.value, param->write.len);
            esp_err_t response_err = esp_ble_gatts_send_response(gatts_if, param->write.conn_id, param->write.trans_id, status, gatt_rsp);
            if (response_err != ESP_OK) {
               ESP_LOGE(GATTS_CELEX, "Send response error");
            free(gatt_rsp);
        }else{
            ESP_LOGE(GATTS_CELEX, "%s, malloc failed", __func__);
    if (status != ESP_GATT_OK){
        return;
    memcpy(prepare_write_env->prepare_buf + param->write.offset,
           param->write.value,
           param->write.len);
    prepare_write_env->prepare_len += param->write.len;
void example_exec_write_event_env(prepare_type_env_t *prepare_write_env, esp_ble_gatts_cb_param_t *param){
    if (param->exec_write.exec_write_flag == ESP_GATT_PREP_WRITE_EXEC && prepare_write_env->prepare_buf){
        esp_log_buffer_hex(GATTS_CELEX, prepare_write_env->prepare_buf, prepare_write_env->prepare_len);
    }else{
        ESP_LOGI(GATTS_CELEX,"ESP_GATT_PREP_WRITE_CANCEL");
    if (prepare_write_env->prepare_buf) {
        free(prepare_write_env->prepare_buf);
        prepare_write_env->prepare_buf = NULL;
static void gatts_profile_A_event_handler(esp_gatts_cb_event_t event, esp_gatt_if_t gatts_if, esp_ble_gatts_cb_param_t *param)
    switch (event) {
        case ESP_GATTS_REG_EVT:{
            esp_err_t set_dev_name_ret = esp_ble_gap_set_device_name(TEST_DEVICE_NAME);
            if (set_dev_name_ret){
                ESP_LOGE(GATTS_CELEX, "set device name failed, error code = %x", set_dev_name_ret);
            esp_err_t raw_adv_ret = esp_ble_gap_config_adv_data_raw(raw_adv_data, sizeof(raw_adv_data));
            if (raw_adv_ret){
                ESP_LOGE(GATTS_CELEX, "config raw adv data failed, error code = %x ", raw_adv_ret);
            adv_config_done |= ADV_CONFIG_FLAG;
            esp_err_t raw_scan_ret = esp_ble_gap_config_scan_rsp_data_raw(raw_scan_rsp_data, sizeof(raw_scan_rsp_data));
            if (raw_scan_ret){
                ESP_LOGE(GATTS_CELEX, "config raw scan rsp data failed, error code = %x", raw_scan_ret);
            adv_config_done |= SCAN_RSP_CONFIG_FLAG;
    #else
            //config adv data
            esp_err_t ret = esp_ble_gap_config_adv_data(&adv_data);
            if (ret){
                ESP_LOGE(GATTS_CELEX, "config adv data failed, error code = %x", ret);
            //config scan response data
            ret = esp_ble_gap_config_adv_data(&scan_rsp_data);
            if (ret){
                ESP_LOGE(GATTS_CELEX, "config scan response data failed, error code = %x", ret);
    #endif
            esp_err_t create_attr_ret = esp_ble_gatts_create_attr_tab(gatt_db, gatts_if, HRS_IDX_NB, SVC_INST_ID);
            if (create_attr_ret){
                ESP_LOGE(GATTS_CELEX, "create attr table failed, error code = %x", create_attr_ret);
        case ESP_GATTS_READ_EVT:
            ESP_LOGI(GATTS_CELEX, "ESP_GATTS_READ_EVT");
        case ESP_GATTS_WRITE_EVT:
            if (!param->write.is_prep){
                // the data length of gattc write  must be less than GATTS_DEMO_CHAR_VAL_LEN_MAX.
                ESP_LOGI(GATTS_CELEX, "GATT_WRITE_EVT, handle = %d, value len = %d, value :", param->write.handle, param->write.len);
                esp_log_buffer_hex(GATTS_CELEX, param->write.value, param->write.len);
                if (heart_rate_handle_table[IDX_CHAR_CFG_A] == param->write.handle && param->write.len == 2){
                    uint16_t descr_value = param->write.value[1]<<8 | param->write.value[0];
                    if (descr_value == 0x0001){
                        ESP_LOGI(GATTS_CELEX, "notify enable");
                        uint8_t notify_data[15];
                        for (int i = 0; i < sizeof(notify_data); ++i)
                            notify_data[i] = i % 0xff;
                        //the size of notify_data[] need less than MTU size
                        esp_ble_gatts_send_indicate(gatts_if, param->write.conn_id, heart_rate_handle_table[IDX_CHAR_VAL_A],
                                                sizeof(notify_data), notify_data, false);
                    }else if (descr_value == 0x0002){
                        ESP_LOGI(GATTS_CELEX, "indicate enable");
                        uint8_t indicate_data[15];
                        for (int i = 0; i < sizeof(indicate_data); ++i)
                            indicate_data[i] = i % 0xff;
                        // if want to change the value in server database, call:
                        // esp_ble_gatts_set_attr_value(heart_rate_handle_table[IDX_CHAR_VAL_A], sizeof(indicate_data), indicate_data);
                        //the size of indicate_data[] need less than MTU size
                                            sizeof(indicate_data), indicate_data, true);
                    else if (descr_value == 0x0000){
                        ESP_LOGI(GATTS_CELEX, "notify/indicate disable ");
                    }else{
                        ESP_LOGE(GATTS_CELEX, "unknown descr value");
                /* send response when param->write.need_rsp is true*/
                    esp_ble_gatts_send_response(gatts_if, param->write.conn_id, param->write.trans_id, ESP_GATT_OK, NULL);
            }else{
                /* handle prepare write */
                example_prepare_write_event_env(gatts_if, &prepare_write_env, param);
        case ESP_GATTS_EXEC_WRITE_EVT:
            // the length of gattc prepare write data must be less than GATTS_DEMO_CHAR_VAL_LEN_MAX.
            ESP_LOGI(GATTS_CELEX, "ESP_GATTS_EXEC_WRITE_EVT");
            example_exec_write_event_env(&prepare_write_env, param);
        case ESP_GATTS_MTU_EVT:
            ESP_LOGI(GATTS_CELEX, "ESP_GATTS_MTU_EVT, MTU %d", param->mtu.mtu);
        case ESP_GATTS_CONF_EVT:
            ESP_LOGI(GATTS_CELEX, "ESP_GATTS_CONF_EVT, status = %d, attr_handle %d", param->conf.status, param->conf.handle);
        case ESP_GATTS_START_EVT:
            ESP_LOGI(GATTS_CELEX, "SERVICE_START_EVT, status %d, service_handle %d", param->start.status, param->start.service_handle);
        case ESP_GATTS_CONNECT_EVT:
            ESP_LOGI(GATTS_CELEX, "ESP_GATTS_CONNECT_EVT, conn_id = %d", param->connect.conn_id);
            esp_log_buffer_hex(GATTS_CELEX, param->connect.remote_bda, 6);
            esp_ble_conn_update_params_t conn_params = {0};
            memcpy(conn_params.bda, param->connect.remote_bda, sizeof(esp_bd_addr_t));
            /* For the iOS system, please refer to Apple official documents about the BLE connection parameters restrictions. */
            conn_params.latency = 0;
            conn_params.max_int = 0x20;    // max_int = 0x20*1.25ms = 40ms
            conn_params.min_int = 0x10;    // min_int = 0x10*1.25ms = 20ms
            conn_params.timeout = 400;    // timeout = 400*10ms = 4000ms
            //start sent the update connection parameters to the peer device.
            esp_ble_gap_update_conn_params(&conn_params);
        case ESP_GATTS_DISCONNECT_EVT:
            ESP_LOGI(GATTS_CELEX, "ESP_GATTS_DISCONNECT_EVT, reason = 0x%x", param->disconnect.reason);
        case ESP_GATTS_CREAT_ATTR_TAB_EVT:{
            if (param->add_attr_tab.status != ESP_GATT_OK){
                ESP_LOGE(GATTS_CELEX, "create attribute table failed, error code=0x%x", param->add_attr_tab.status);
            else if (param->add_attr_tab.num_handle != HRS_IDX_NB){
                ESP_LOGE(GATTS_CELEX, "create attribute table abnormally, num_handle (%d) \
                        doesn't equal to HRS_IDX_NB(%d)", param->add_attr_tab.num_handle, HRS_IDX_NB);
            else {
                ESP_LOGI(GATTS_CELEX, "create attribute table successfully, the number handle = %d",param->add_attr_tab.num_handle);
                memcpy(heart_rate_handle_table, param->add_attr_tab.handles, sizeof(heart_rate_handle_table));
                esp_ble_gatts_start_service(heart_rate_handle_table[IDX_SVC]);
        case ESP_GATTS_STOP_EVT:
        case ESP_GATTS_OPEN_EVT:
        case ESP_GATTS_CANCEL_OPEN_EVT:
        case ESP_GATTS_CLOSE_EVT:
        case ESP_GATTS_LISTEN_EVT:
        case ESP_GATTS_CONGEST_EVT:
        case ESP_GATTS_UNREG_EVT:
        case ESP_GATTS_DELETE_EVT:
        default:
static void gatts_profile_B_event_handler(esp_gatts_cb_event_t event, esp_gatt_if_t gatts_if, esp_ble_gatts_cb_param_t *param)
    switch (event)
        // TEST_DEVICE_NAME = Name;
        // ESP_LOGE(Device_name_log, "deviceName:%s", TEST_DEVICE_NAME);
        // esp_err_t set_dev_name_ret = esp_ble_gap_set_device_name(SAMPLE_DEVICE_NAME);
        if (raw_adv_ret)
        adv_config_done |= adv_config_flag;
        if (raw_scan_ret)
        adv_config_done |= scan_rsp_config_flag;
#else
        // config adv data
        // esp_err_t ret = esp_ble_gap_config_adv_data(&adv_data);
        // if (ret)
        //     ESP_LOGE(GATTS_CELEX, "config adv data failed, error code = %x", ret);
        // adv_config_done |= adv_config_flag;
        // // config scan response data
        // ret = esp_ble_gap_config_adv_data(&scan_rsp_data);
        // if (ret)
        //     ESP_LOGE(GATTS_CELEX, "config scan response data failed, error code = %x", ret);
        // adv_config_done |= scan_rsp_config_flag;
#endif
        esp_err_t create_attr_ret = esp_ble_gatts_create_attr_tab(gatt2_db, gatts_if, HRS2_IDX_NB, SVC_INST_ID);
        ESP_LOGE(GATTS_CELEX, " ADD  USER Service %d param->add_char.attr_handle %d", gatts_if, param->add_char.attr_handle);
        ESP_LOGE(GATTS_CELEX, "GATT_READ_EVT, gatts_if %d, conn_id %d, trans_id %d, handle %d\n", gatts_if, param->read.conn_id, param->read.trans_id, param->read.handle);
        esp_gatt_rsp_t rsp;
        memset(&rsp, 0, sizeof(esp_gatt_rsp_t));
        rsp.attr_value.handle = param->read.handle;
        rsp.attr_value.len = 4;
        rsp.attr_value.value[0] = 0xde;
        rsp.attr_value.value[1] = 0xed;
        rsp.attr_value.value[2] = 0xbe;
        rsp.attr_value.value[3] = 0xef;
        esp_ble_gatts_send_response(gatts_if, param->read.conn_id, param->read.trans_id,
                                    ESP_GATT_OK, &rsp);
        // writeFlg = 1;
        ESP_LOGI(GATTS_CELEX, "GATT_WRITE_EVT, conn_id %d, trans_id %d, handle %d", param->write.conn_id, param->write.trans_id, param->write.handle);
            // ESP_LOGI(GATTS_CELEX, "GATT_WRITE_EVT, value len %d, value :", param->write.len);
            // esp_log_buffer_hex(GATTS_CELEX, param->write.value, param->write.len);
            // // 添加接收数据处理逻辑
            // Robert_BLEAnalysis(param);
        example_write_event_env(gatts_if, &a_prepare_write_env, param);
        example_exec_write_event_env(&a_prepare_write_env, param);
    case ESP_GATTS_CREATE_EVT:
        ESP_LOGE(GATTS_CELEX, "CREATE_SERVICE_EVT, status %d,  service_handle %d\n", param->create.status, param->create.service_handle);
        // ESP_LOGI(GATTS_CELEX, "CREATE_SERVICE_EVT, status %d,  service_handle %d\n", param->create.status, param->create.service_handle);
        heart_rate_profile_tab[PROFILE_C_APP_ID].service_handle = param->create.service_handle;
        heart_rate_profile_tab[PROFILE_C_APP_ID].char_uuid.len = ESP_UUID_LEN_128;
        // heart_rate_profile_tab[PROFILE_A_APP_ID].char_uuid.uuid.uuid16 = GATTS_CHAR_UUID_TEST_A;
        for (int i = 0; i < 16; i++)
            /* code */
            heart_rate_profile_tab[PROFILE_C_APP_ID].char_uuid.uuid.uuid128[i] = service_uuid[i];
        esp_ble_gatts_start_service(heart_rate_profile_tab[PROFILE_C_APP_ID].service_handle);
        a_property = ESP_GATT_CHAR_PROP_BIT_WRITE | ESP_GATT_CHAR_PROP_BIT_NOTIFY; // ESP_GATT_CHAR_PROP_BIT_READ | ESP_GATT_CHAR_PROP_BIT_WRITE | ESP_GATT_CHAR_PROP_BIT_NOTIFY;
        esp_err_t add_char_ret = esp_ble_gatts_add_char(param->create.service_handle, &heart_rate_profile_tab[PROFILE_C_APP_ID].char_uuid,
                                                        ESP_GATT_PERM_WRITE, /// ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
                                                        a_property,
                                                        &gatts_demo_char1_val, NULL);
        if (add_char_ret)
            ESP_LOGE(GATTS_CELEX, "add char failed, error code =%x", add_char_ret);
    case ESP_GATTS_ADD_INCL_SRVC_EVT:
    case ESP_GATTS_ADD_CHAR_EVT:
        // uint16_t length = 0;
        // const uint8_t *prf_char;
        ESP_LOGE(GATTS_CELEX, "ssssssssssssssssADD_CHAR_EVT, status %d,  attr_handle %d, service_handle %d\n",
                 param->add_char.status, param->add_char.attr_handle, param->add_char.service_handle);
    case ESP_GATTS_ADD_CHAR_DESCR_EVT:
        heart_rate_profile_tab[PROFILE_C_APP_ID].descr_handle = param->add_char_descr.attr_handle;
        ESP_LOGI(GATTS_CELEX, "ADD_DESCR_EVT, status %d, attr_handle %d, service_handle %d\n",
                 param->add_char_descr.status, param->add_char_descr.attr_handle, param->add_char_descr.service_handle);
        ESP_LOGI(GATTS_CELEX, "SERVICE_START_EVT, status %d, service_handle %d\n",
        /* For the IOS system, please reference the apple official documents about the ble connection parameters restrictions. */
        conn_params.max_int = 0x40;//0x20; // max_int = 0x20*1.25ms = 40ms
        conn_params.min_int = 0x20;//0x10; // min_int = 0x10*1.25ms = 20ms
        conn_params.timeout = 1000;  // timeout = 400*10ms = 4000ms
        ESP_LOGI(GATTS_CELEX, "ESP_GATTS_CONNECT_EVT 2 service, conn_id %d, remote %02x:%02x:%02x:%02x:%02x:%02x:",
                 param->connect.conn_id,
                 param->connect.remote_bda[0], param->connect.remote_bda[1], param->connect.remote_bda[2],
                 param->connect.remote_bda[3], param->connect.remote_bda[4], param->connect.remote_bda[5]);
        heart_rate_profile_tab[PROFILE_C_APP_ID].conn_id = param->connect.conn_id;
        // start sent the update connection parameters to the peer device.
        // ConnectedFlag = 1;
        // esp_ble_gap_set_device_name(TEST_DEVICE_NAME11);
        // ESP_LOGI(GATTS_TAG, "ESP_GATTS_DISCONNECT_EVT, disconnect reason 0x%x", param->disconnect.reason);
        // if (CloseFlg == 1)
        //     esp_ble_gap_stop_advertising();
        //     ESP_LOGI(GATTS_TAG, "close BLE");
        // else
        //     esp_ble_gap_start_advertising(&adv_params);
        //     ESP_LOGI(GATTS_TAG, "start BLE");
        // ConnectedFlag = 0;
            ESP_LOGE(GATTS_CELEX, "create  user attribute table failed, error code=0x%x", param->add_attr_tab.status);
        else if (param->add_attr_tab.num_handle != HRS2_IDX_NB)
                    doesn't equal to HRS2_IDX_NB(%d)",
                     param->add_attr_tab.num_handle, HRS2_IDX_NB);
        else
            ESP_LOGI(GATTS_CELEX, "create user attribute table successfully, the number handle = %d\n", param->add_attr_tab.num_handle);
            memcpy(heart_2rate_handle_table, param->add_attr_tab.handles, sizeof(heart_2rate_handle_table));
            esp_ble_gatts_start_service(heart_2rate_handle_table[IDX2_SVC]);
    default:
        if (param->write.is_prep)
                    ESP_LOGE(GATTS_CELEX, "Gatt_server prep no mem\n");
            else
                ESP_LOGE(GATTS_CELEX, "Send response error\n");
            free(gatt_rsp);
                return;
                   param->write.value,
                   param->write.len);
        else
            esp_ble_gatts_send_response(gatts_if, param->write.conn_id, param->write.trans_id, status, NULL);
static void gatts_event_handler(esp_gatts_cb_event_t event, esp_gatt_if_t gatts_if, esp_ble_gatts_cb_param_t *param)
    /* If event is register event, store the gatts_if for each profile */
    if (event == ESP_GATTS_REG_EVT) {
        if (param->reg.status == ESP_GATT_OK) {
            heart_rate_profile_tab[PROFILE_A_APP_IDX].gatts_if = gatts_if;
            ESP_LOGE(GATTS_CELEX, "reg app failed, app_id %04x, status %d",
                    param->reg.app_id,
                    param->reg.status);
            return;
    do {
        int idx;
        for (idx = 0; idx < PROFILE_NUM; idx++) {
            /* ESP_GATT_IF_NONE, not specify a certain gatt_if, need to call every profile cb function */
            if (gatts_if == ESP_GATT_IF_NONE || gatts_if == heart_rate_profile_tab[idx].gatts_if) {
                if (heart_rate_profile_tab[idx].gatts_cb) {
                    heart_rate_profile_tab[idx].gatts_cb(event, gatts_if, param);
    } while (0);
void User_BLE_Init(void)
    esp_err_t ret;
    esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
    ret = esp_bt_controller_init(&bt_cfg);
    if (ret) {
        ESP_LOGE(GATTS_CELEX, "%s enable controller failed: %s", __func__, esp_err_to_name(ret));
        return;
    ret = esp_bt_controller_enable(ESP_BT_MODE_BLE);
    if (ret) {
        return;
    ret = esp_bluedroid_init();
    if (ret) {
        ESP_LOGE(GATTS_CELEX, "%s init bluetooth failed: %s", __func__, esp_err_to_name(ret));
        return;
    ret = esp_bluedroid_enable();
    if (ret) {
        ESP_LOGE(GATTS_CELEX, "%s enable bluetooth failed: %s", __func__, esp_err_to_name(ret));
        return;
    ret = esp_ble_gatts_register_callback(gatts_event_handler);
    if (ret){
        ESP_LOGE(GATTS_CELEX, "gatts register error, error code = %x", ret);
        return;
    ret = esp_ble_gap_register_callback(gap_event_handler);
    if (ret){
        ESP_LOGE(GATTS_CELEX, "gap register error, error code = %x", ret);
        return;
    ret = esp_ble_gatts_app_register(ESP_APP_ID);
    if (ret){
        ESP_LOGE(GATTS_CELEX, "gatts app register error, error code = %x", ret);
        return;
    esp_err_t local_mtu_ret = esp_ble_gatt_set_local_mtu(500);
    if (local_mtu_ret){
        ESP_LOGE(GATTS_CELEX, "set local  MTU failed, error code = %x", local_mtu_ret);
Robert-qiao
Re: esp32-c3 新建蓝牙服务问题
Postby Robert-qiao » Sun Aug 11, 2024 12:06 pm
esp-idf V5.0版本以上不支持打印uint32_t 类型数据,因为之前使用的是V4.3.4版本移植过来的,去除掉即可
Users browsing this forum: No registered users and 7 guests
