ESP32-S3-BOX-3B no longer responds
ganbaranba
Postby ganbaranba » Sun Nov 17, 2024 6:28 pm
Initially, the ESP32-S3-BOX-3B was turning on when connected to my Mac, and I was able to connect to it via esptool, flash it etc.
However, now it shows briefly as a "USB/JTAG debug unit" (maybe for a second) and disappears - this happens on another mac, with other cables etc, so I'm pretty sure it's not dependent on the machine I'm connecting it to or cables.
I tried pressing boot and reset then releasing boot button. Also tried holding boot button and unplugging / replugging usb c cable.
Is there any option besides trying to flash via USB to UART? Is there any easy way to do USB to UART flashing, or will I need to disassemble?
In `dmesg` on mac, I seee messages like this:
[ 4298.750165]: AppleUSBIORequest: AppleUSBIORequest::complete: device 3 (USB JTAG/serial debug unit@02110000) endpoint 0x82: status 0xe00002ed (transaction error): 0 bytes transferred
[ 4298.753079]: AppleUSB20HubPort@02110000: AppleUSBHostPort::terminateDevice: destroying 0x303a/1001/0101 (USB JTAG/serial debug unit): hardware connection lost
[ 4298.755977]: AppleUSBIORequest: AppleUSBIORequest::complete: device 3 (USB JTAG/serial debug unit@02110000) endpoint 0x82: status 0xe00002ed (transaction error): 0 bytes transferred
ESP_Xuxin
Re: ESP32-S3-BOX-3B no longer responds
Postby ESP_Xuxin » Mon Nov 18, 2024 2:54 am
Hello,Is your newly burned program occupying the USB pins, or is it constantly restarting?
ganbaranba
Postby ganbaranba » Mon Nov 18, 2024 2:35 pm
Thanks for the reply @ESP_Xuxin!
How could I figure this out?
Here's what I can observe:
* Shows up briefly (a second) in ESP Launchpad connect window, then disappears
* Shows up briefly (a second) via lsusb then leaves
* I can press the mute microphone button and the orange LED comes on
I don't think I can do much more observation because the USB connection doesn't work, so I can't use esptool etc.
Any other ideas on what I could do?
ESP_Sprite
Postby ESP_Sprite » Tue Nov 19, 2024 1:21 am
If you want to try flashing something else into the Box, you can try holding the 'boot' button, then pressing and releasing the 'reset' button, then releasing the 'boot' button. This should allow you to flash the unit again. Note that after flashing you may need to press the 'reset' button to start the flashed program.
ganbaranba
Postby ganbaranba » Wed Nov 20, 2024 9:12 am
Hi ESP_Sprite,
Thanks for your response.
Actually, I previously tried this a few times:
Even when I do this, the same behavior continues, i.e.
Since it only shows up for a second and then disappears (this happens in `lsusb` as well as ESP Launchpad etc), I don't think there's any way for me to flash something new onto it.
ESP_Xuxin
Postby ESP_Xuxin » Fri Nov 22, 2024 12:22 pm
Please confirm whether the device has entered boot mode. Press and hold boot first, then press reset or power on. Boot key is the one above.
Boot mode has nothing to do with the application, unless the board is really broken.
Users browsing this forum: No registered users and 16 guests
