ESP32-S3-Box-3 Battery Not Working
Bytelink
Postby Bytelink » Wed Oct 09, 2024 6:49 pm
When I placed a fully charged battery into the Box-3 Dock it does not power the device.
The Sensors in the dock all appear to work when it is plugged into the USB Port however the battery does not seem to power up the sensors or the device and the battery level indicates 0 in home assistant
ESP_Rachel
Re: ESP32-S3-Box-3 Battery Not Working
Postby ESP_Rachel » Fri Oct 25, 2024 10:04 am
Is the battery you're using an 18650 rechargeable battery? Have you tried replacing it with another battery to rule out any battery-related issues?
Bytelink
Postby Bytelink » Wed Nov 06, 2024 10:02 pm
Rachael
Sorry I did not see the reply. Yes I am using 18650 rechargeable battery and I have tried two different batteries that I charged externally but still the unit does not power up. If I plug the usb into the battery base it powers up the unit but not with a battery.
I rally bought the unit as where I want to use it I need to use the battery.
hramrach
Postby hramrach » Thu Dec 05, 2024 3:10 am
What is a '18650 rechargeable battery'?
What chemistry is supported?
LiFePO4? Na-ion?
Tried a Westinghouse 2600mAh 🦁 battery, the cheapest 🦁 the local hardware store has.
It does work in the sense that after
- switching the battery on by the sensor base switch
- charging the battery for about 10 minutes (red light on base is on)
disconnecting the power source does not lead to immediate poweroff of the esp32-box
