ESP32-WROOM-32E Bluetooth SIG certification
Posted: Tue Nov 15, 2022 2:04 pm
by dahookas
We use ESP32-WROOM-32E module in our product and are trying to get is Bluetooth-SIG certified.
However, when trying to use the provided QDID 124871 for Component (Tested), I get an error from
Bluetooth SIG Launch Studio that it is expired:
Expired: The 3 year period for component 124871, Bluetooth Chip has expired. You cannot reference component 124871 in your test plan or test declaration, unless reassessment is performed by the listing owner. If reassessment is not performed by the listing owner and you use component 124871, you will be required to re-perform all testing.
Does Espressif plan to reassess this module? If not - what are your suggestions for replacement?
Planned product amounts are 100K or more during upcoming two years.
Thanks,
Darius Pečkys
Re: ESP32-WROOM-32E Bluetooth SIG certification
Posted: Thu Nov 17, 2022 11:23 am
by ESP_Sun
Maybe you can refer to the information in the attachment below and hope it will be helpful to you.
Posted: Thu Nov 17, 2022 12:12 pm
by dahookas
You have replied with a screenshot from LaunchStudio, many thanks, but that IS my question: <start of question> Since Bluetooth SIG states the qualified design id for WROOM-32E is expired and consequently - not usable for SIG qualification without full re-testing
(as per Bluetooth SIG: "You cannot reference component 124871 in your test plan or test declaration, unless reassessment is performed by the listing owner. If reassessment is not performed by the listing owner and you use component 124871, you will be required to re-perform all testing."), does Espressif as a listing owner plan to reassess WROOM-32E module? <end of question>
Answers can be: Yes/No
Thank you.
Darius Pečkys
Posted: Fri Nov 18, 2022 5:03 am
by ESP_Sun
The QDID of ESP32-WROOM-32E is 152314. 124871 is the QDID of the related chip. If you use a module, you can use 152314.
Posted: Mon Jun 26, 2023 11:20 pm
by Norman Ballard
Hi. We are using the ESP32-D0WD-V3 chip and so we believe we need to reference 124871 but it is expired. What can we do?
