ESP32 wifi getting disconnected once within 3-4 days
sd.hrishi
Postby sd.hrishi » Tue Jan 17, 2023 5:30 am
I integrated ESP32 (ESP32 DEVKITC V4) with the Blynk IoT platform. I observed that my ESP32 is getting disconnected once in a while from Wifi. I added a patch to restart ESP (ESP.restart()) if it is not connected to Wifi for the last 30 minutes. Sometimes this works but not always. I have to turn off the power supply and then turn it on. And then it gets to connect to Wifi within a few seconds.
I tried with esps, but no luck.
I'm not sure what is the reason.
Here is the program:
[Codebox]//#define BLYNK_DEBUG // Optional, this enables more detailed prints
//#define BLYNK_PRINT Serial // Defines the object that is used for printing
#define BLYNK_TEMPLATE_ID "<<Replace-me>>"
#define BLYNK_DEVICE_NAME "<<Replace-me>>"
#define BLYNK_AUTH_TOKEN "<<Replace-me>>"
#define BLYNK_FIRMWARE_VERSION "0.1.2"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#define WIFI_LED 26
#define SENSOR_PIN 36
#define VPIN_0 V0
#define RELAY_PIN 5
#define PUMP_IDEAL 0
#define PUMP_RUNNING 1
#define PUMP_FORCE_KILL_IN_MINS 15 // IN MINS
#define HARD_RESTART_AFTER 30 // IN MINS
char auth[] = BLYNK_AUTH_TOKEN;
int wifiFlag = 0;
int pumpState =0; //PUMP_IDEAL, PUMP_RUNNING
int pumpStartTime =0; //In millis
int lastConnected = 0;
bool forceKilled = false;
int pumpRunDurationInMinsInFroceKill = 0;
char ssid[] = "<<Replace-me>>";
char pass[] = "<<Replace-me>>";
BlynkTimer timer;
BLYNK_WRITE(VPIN_0)
int val = param.asInt();
if(val ==1){
pumpState=PUMP_RUNNING;
pumpStartTime=millis();
Serial.println("Pump Started ");
Blynk.logEvent("pump_start", String("Pump Started."));
digitalWrite(RELAY_PIN, LOW);
}else {
digitalWrite(RELAY_PIN, HIGH);
double totalTimePumpRun = (double) (millis() - pumpStartTime)/(1000.0*60.0); //mins
pumpStartTime = 0;
if(pumpState == PUMP_RUNNING) {
Serial.println(String("Pump runs (Mins) : ") + totalTimePumpRun);
Blynk.logEvent("pump_stopped", String("Pump runs (in Mins): ") + totalTimePumpRun) ;
Blynk.virtualWrite(V1, totalTimePumpRun);
}else {
Blynk.logEvent("pump_stopped", String("[Without Start Data] Pump runs (in Mins): ") + totalTimePumpRun) ;
pumpState=PUMP_IDEAL;
void checkBlynkStatus() {
// HARD RESTART
if(millis() - lastConnected > HARD_RESTART_AFTER*60*1000){
lastConnected = millis();
ESP.restart();
// FORCE KILL;
if(pumpState == PUMP_RUNNING){
pumpRunDurationInMinsInFroceKill = (millis() - pumpStartTime) /(1000*60) ;
if(pumpRunDurationInMinsInFroceKill >= PUMP_FORCE_KILL_IN_MINS){
forceKilled = true;
Serial.println("Force Killed Pump after (in mins) : " + pumpRunDurationInMinsInFroceKill);
float sensorValue = analogRead(SENSOR_PIN);
int moisture = (int) (100 -(sensorValue/4095)*100);
bool isconnected = Blynk.connected();
if (isconnected == false) {
wifiFlag = 1;
WiFi.reconnect();
digitalWrite(WIFI_LED, LOW);
} else {
wifiFlag = 0;
digitalWrite(WIFI_LED, HIGH);
Blynk.virtualWrite(V2, moisture);
if(forceKilled){
Blynk.virtualWrite(VPIN_0, 0);
pumpRunDurationInMinsInFroceKill = (pumpRunDurationInMinsInFroceKill <= 0)?1:pumpRunDurationInMinsInFroceKill;
Blynk.virtualWrite(V1, pumpRunDurationInMinsInFroceKill);
Blynk.logEvent("force_kill", String("Foce Killed pump after (in mis)" )+ pumpRunDurationInMinsInFroceKill);
BLYNK_CONNECTED() {
Blynk.syncVirtual(VPIN_0);
void setup(){
Serial.begin(9600);
Serial.println("Planto-Hydra is starting.");
pinMode(RELAY_PIN, OUTPUT);
pinMode(WIFI_LED, OUTPUT);
timer.setInterval(2000L, checkBlynkStatus);
Blynk.begin(auth, ssid, pass);
Serial.println("Planto-Hydra Setup completed.");
void loop()
Blynk.run();
timer.run();
}[/Codebox]
esp-at
Re: ESP32 wifi getting disconnected once within 3-4 days
Postby esp-at » Mon Jan 30, 2023 3:48 am
Here is the forum for esp-at project: https://github.com/espressif/esp-at, i am not sure if you post a wrong place for your issue.
if you use esp-at firmware, please provide more details, such as AT+GMR, and AT logs.
Users browsing this forum: No registered users and 9 guests
