Rainmaker stops when I enable Insights
themindfactory
Postby themindfactory » Tue Nov 05, 2024 6:57 pm
I have 100% running Rainmaker code in Arduino environment, but when I init() Insights Rainmaker stops working correctly, it looks like it affects it sending device information to the app via mqtt.
Is there an order or timing that must be followed to allow this?
Richard.
themindfactory
Re: Rainmaker stops when I enable Insights
Postby themindfactory » Tue Nov 05, 2024 9:30 pm
A little further investigation it looks like when its called the MQTT disconnects. I tried calling it first in setup(); and tried delaying it to the end of boot up and it does the same thing both times.
R.
themindfactory
Postby themindfactory » Tue Nov 05, 2024 10:21 pm
Just trying HTTPS route... is this the reason MQTT and HTTPS exist for Insights? Incase you use both?
Users browsing this forum: No registered users and 71 guests
