Rainmaker instability - repeated uninvited reset
Posted: Tue May 28, 2024 1:02 pm
Went back to the basic vanilla Switch example. Way to reproduce:
1. Enrol the switch.
2. On and Off from the app works fine. form the button, not always stable.
3. Wait 5 minutes.
4. Hit the button for a short time.
5. The device immediately resets itself.
Note in the logs the wait gap between time 129930 to 424580.
I ruled out any "mechanical" problem with the button being pulled up. a simple sketch of digitalWrite(32,digitalRead(34));
works perfectly well my setup.
This is repeating itself almost every time.
I (117050) app_main: MQTT Published. Msg id: 53825.
I (117090) esp_rmaker_node_config: Generated Node config of length 1466
I (117190) app_main: MQTT Published. Msg id: 53470.
I (117230) app_main: MQTT Published. Msg id: 33547.
I (126940) app_reset: Release button to trigger factory reset.
I (127120) esp_rmaker_node_config: Generated Node config of length 1466
W (129930) httpd_txrx: httpd_sock_err: error in recv : 104
I (292420) esp_rmaker_time: SNTP Synchronised.
I (292420) esp_rmaker_time: The current time is: Tue May 28 15:54:47 2024 +0300[IDT], DST: Yes.
I (424570) app_main: Node reset to factory defaults.
I (424580) esp_rmaker_user_mapping: User Node mapping reset detected.
I (424580) esp_rmaker_user_mapping: MQTT Publish: {"node_id":"CeUTsx5925JpFvLJPxKjMm","user_id":"esp-rmaker","secret_key":"failed","reset":true}
I (424850) app_main: MQTT Published. Msg id: 42029.
I (424850) esp_rmaker_user_mapping: User Node association message published successfully.
W (424860) app_main: Unhandled RainMaker Event: 7
I (426810) app_main: Rebooting in 2 seconds.
I (428790) app_reset: Release button now for Wi-Fi reset. Keep pressed for factory reset.
I (428810) wifi:state: run -> init (0)
I (428810) wifi:pm stop, total sleep time: 326718183 us / 370442854 us
I (428810) wifi:<ba-del>idx:1, tid:0
I (428810) wifi:<ba-del>idx:0, tid:6
I (428810) wifi
<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
E (428820) wifi:NAN WiFi stop
I (428820) app_wifi: Disconnected. Connecting to the AP again...
E (428830) transport_base: poll_read select error 113, errno = Software caused connection abort, fd = 54
E (428840) mqtt_client: Poll read error: 119, aborting connection
W (428850) esp_mqtt_glue: MQTT Disconnected. Will try reconnecting in a while...
I (428850) app_main: MQTT Disconnected.
I (428860) wifi:flush txq
I (428860) wifi:stop sw txq
I (428860) wifi:lmac stop hw txq
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:7172
load:0x40078000,len:15628
load:0x40080400,len:4
0x40080400: _init at ??:?
load:0x40080404,len:3904
entry 0x40080640
I (29) boot: ESP-IDF v5.2.1-dirty 2nd stage bootloader
I (29) boot: compile time May 27 2024 20:11:37
I (29) boot: Multicore bootloader
I (34) boot: chip revision: v1.0
I (38) boot.esp32: SPI Speed : 40MHz
I (42) boot.esp32: SPI Mode : DIO
I (47) boot.esp32: SPI Flash Size : 4MB
I (51) boot: Enabling RNG early entropy source...
I (57) boot: Partition Table:
I (60) boot: ## Label Usage Type ST Offset Length
I (68) boot: 0 esp_secure_cert unknown 3f 06 0000d000 00002000
I (75) boot: 1 nvs_key NVS keys 01 04 0000f000 00001000
I (83) boot: 2 nvs WiFi data 01 02 00010000 00006000
I (90) boot: 3 otadata OTA data 01 00 00016000 00002000
I (98) boot: 4 phy_init RF data 01 01 00018000 00001000
I (105) boot: 5 ota_0 OTA app 00 10 00020000 00190000
I (113) boot: 6 ota_1 OTA app 00 11 001b0000 00190000
I (120) boot: 7 fctry WiFi data 01 02 00340000 00006000
I (128) boot: End of partition table
I (132) esp_image: segment 0: paddr=00020020 vaddr=3f400020 size=4e714h (321300) map
I (251) esp_image: segment 1: paddr=0006e73c vaddr=3ffbdb60 size=018dch ( 6364) load
I (253) esp_image: segment 2: paddr=00070020 vaddr=400d0020 size=108434h (1082420) map
I (627) esp_image: segment 3: paddr=0017845c vaddr=3ffbf43c size=0428ch ( 17036) load
I (634) esp_image: segment 4: paddr=0017c6f0 vaddr=40080000 size=1e418h (123928) load
I (698) boot: Loaded app from partition at offset 0x20000
I (698) boot: Disabling RNG early entropy source...
I (710) cpu_start: Multicore app
I (718) cpu_start: Pro cpu start user code
I (718) cpu_start: cpu freq: 160000000 Hz
I (719) cpu_start: Application information:
I (722) cpu_start: Project name: switch
I (726) cpu_start: App version: 1.0
I (731) cpu_start: Compile time: May 28 2024 15:49:01
I (737) cpu_start: ELF file SHA256: d616600c9...
I (742) cpu_start: ESP-IDF: v5.2.1-dirty
I (748) cpu_start: Min chip rev: v0.0
I (753) cpu_start: Max chip rev: v3.99
I (757) cpu_start: Chip rev: v1.0
I (762) heap_init: Initializing. RAM available for dynamic allocation:
I (769) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM
I (775) heap_init: At 3FFB6388 len 00001C78 (7 KiB): DRAM
I (781) heap_init: At 3FFB9A20 len 00004108 (16 KiB): DRAM
I (788) heap_init: At 3FFCB148 len 00014EB8 (83 KiB): DRAM
I (794) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (800) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (807) heap_init: At 4009E418 len 00001BE8 (6 KiB): IRAM
I (815) spi_flash: detected chip: generic
I (817) spi_flash: flash io: dio
I (823) coexist: coex firmware version: 77cd7f8
I (828) main_task: Started on CPU0
I (838) main_task: Calling app_main()
I (838) esp_rmaker_console: Initialising UART on port 0
I (838) uart: queue free spaces: 8
I (838) esp_rmaker_commands: Registering command: reboot
I (848) esp_rmaker_commands: Registering command: up-time
I (848) esp_rmaker_commands: Registering command: mem-dump
I (858) esp_rmaker_commands: Registering command: task-dump
I (868) esp_rmaker_commands: Registering command: cpu-dump
I (868) esp_rmaker_commands: Registering command: sock-dump
I (878) esp_rmaker_commands: Registering command: heap-trace
I (888) esp_rmaker_commands: Registering command: reset-to-factory
I (888) esp_rmaker_commands: Registering command: local-time
I (898) esp_rmaker_commands: Registering command: tz-set
I (898) esp_rmaker_commands: Registering command: add-user
I (908) esp_rmaker_commands: Registering command: get-node-id
I (918) esp_rmaker_commands: Registering command: wifi-prov
I (918) esp_rmaker_commands: Registering command: cmd
I (928) gpio: GPIO[34]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3
I (938) gpio: GPIO[32]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 1| Intr:0
W (948) ws2812_led: WS2812 LED is disabled
I (988) wifi:wifi driver task: 3ffd1df8, prio:23, stack:6656, core=0
I (988) wifi:wifi firmware version: a9f5b59
I (988) wifi:wifi certification version: v7.0
I (988) wifi:config NVS flash: enabled
I (988) wifi:config nano formating: disabled
I (998) wifi:Init data frame dynamic rx buffer num: 32
I (998) wifi:Init static rx mgmt buffer num: 5
I (1008) wifi:Init management short buffer num: 32
I (1008) wifi:Init dynamic tx buffer num: 32
I (1008) wifi:Init static rx buffer size: 1600
I (1018) wifi:Init static rx buffer num: 10
I (1018) wifi:Init dynamic rx buffer num: 32
I (1028) wifi_init: rx ba win: 6
I (1028) wifi_init: tcpip mbox: 32
I (1028) wifi_init: udp mbox: 6
I (1038) wifi_init: tcp mbox: 6
I (1038) wifi_init: tcp tx win: 5760
I (1048) wifi_init: tcp rx win: 5760
I (1048) wifi_init: tcp mss: 1440
I (1048) wifi_init: WiFi IRAM OP enabled
I (1058) wifi_init: WiFi RX IRAM OP enabled
I (1078) esp_rmaker_work_queue: Work Queue created.
I (1098) esp_mqtt_glue: AWS PPI: ?Platform=APN3|A0|RM|EX00|RMDev|1x0|7821847D5DB8
I (1098) esp_mqtt_glue: Initialising MQTT
I (1098) esp_rmaker_mqtt_budget: MQTT Budgeting initialised. Default: 100, Max: 1024, Revive count: 1, Revive period: 5
I (1118) app_main: RainMaker Initialised.
I (1118) esp_rmaker_node: Node ID ----- CeUTsx5925JpFvLJPxKjMm
I (1128) esp_rmaker_ota_using_topics: OTA enabled with Topics
I (1138) esp_rmaker_ota: OTA state = 2
I (1138) esp_rmaker_time: Initializing SNTP. Using the SNTP server: pool.ntp.org
I (1148) esp_rmaker_time_service: Time service enabled
I (1148) esp_rmaker_time: SNTP already initialized.
I (1158) app_insights: Enable CONFIG_ESP_INSIGHTS_ENABLED to get Insights.
I (1158) esp_rmaker_core: Starting RainMaker Work Queue task
I (1168) esp_rmaker_work_queue: RainMaker Work Queue task started.
I (1178) tag: 0x3ffdb830 e5 02 4e 6f 76 61 00 01 00 80 01 00 |..Nova......|
I (1188) wifi_prov_scheme_ble: BT memory released
I (1188) app_wifi: Starting provisioning
I (1208) phy_init: phy_version 4791,2c4672b,Dec 20 2023,16:06:06
W (1208) phy_init: failed to load RF calibration data (0x1102), falling back to full calibration
I (1298) wifi:mode : sta (78:21:84:7d:5d:b8)
I (1298) wifi:enable tsf
I (1308) BTDM_INIT: BT controller compile version [0f0c5a2]
I (1308) BTDM_INIT: Bluetooth MAC: 78:21:84:7d:5d:ba
I (1558) protocomm_nimble: BLE Host Task Started
I (1568) wifi_prov_mgr: Provisioning started with service name : PROV_36fb86
I (1578) app_wifi: Provisioning started
I (1578) esp_rmaker_local: Event 1
I (1578) app_wifi: Scan this QR code from the ESP RainMaker phone app for Provisioning.
3. Wait 5 minutes.
I (428810) wifi
![:new:](http://cdn.jsdelivr.net/emojione/assets/3.1/png/64/1f195.png)
entry 0x40080640
