How to send several values in PROP_FLAG_TIME_SERIES time series in one MQTT message
Posted: Wed Mar 13, 2024 11:44 am
by KaosESP32
Hi I'm trying to send several values (one per second) in single MQTT message with a higher frequency (let's say one message per minute)
My understanding is that this should be accomplished with full time series flag parameter (PROP_FLAG_TIME_SERIES) but I'm not able to found documentation nor example on the docs how to do it. Specifically, how to populate the parameter with 60 different pairs (time, value)
Anyone can provide pointers to documentation or/and examples?
Thanks in advance
Re: How to send several values in PROP_FLAG_TIME_SERIES time series in one MQTT message
Posted: Wed Mar 13, 2024 11:50 am
by ESP_Piyush
Currently, we do not have an API for this, but you can format the data as per the specifications mentioned
here. Meanwhile, even though sending a message once per minute fits into our fair usage policy, a data point every second is still quite a huge data. Does your use case really require such high rate?
Posted: Wed Mar 13, 2024 5:02 pm
by KaosESP32
Hi again,
Thanks a lot for your VERY fast response, I appreciate it.
I understand that is a lot of data, it was just an example to facilitate de explanation of what I intend to do.
To be sure that I understand correctly your answer, do you mean that using the api "esp_rmaker_mqtt_publish" with the correct payload and topic pointed by the documentation is 100% equivalent to use the esp_rmaker_param_update_and_report api?
Cesc
Posted: Wed Mar 13, 2024 5:15 pm
by ESP_Piyush
Yes, the understanding is correct. Formatting the data into correct JSON representation and sending on the topics is equivalent to calling the C APIs. You can write your own wrappers for time series data.
Posted: Wed Mar 13, 2024 5:18 pm
by KaosESP32
Many Thanks !
