Even after initiating a board reset, the challenge persists in establishing a connection to another device through the E
Posted: Thu Jan 11, 2024 12:40 pm
by gunadeepaksai
When I flashed the leg_light glowing application onto the ESP32 C3 module and attempted to connect to WiFi using the Rain Maker app provided by Espressif, I encountered an issue. While the device successfully connected initially, upon disconnection, it continued searching for the previous device even after resetting the board. This behavior necessitated re-flashing the board to establish a connection with another device using the Rain Maker app. Is there any solution to disconnect and restore wifi settings without reflashing the code
Screenshot from 2024-01-11 18-04-37.png (195.86 KiB) Viewed 30260 times
--->Wifi Display after flashing
---->Getting strucked here after disconnecting
Re: Even after initiating a board reset, the challenge persists in establishing a connection to another device through t
Posted: Mon Jan 15, 2024 5:49 pm
by ESP_Piyush
Did you just reboot the board or pressed and held the boot button for 3+ or 10+ seconds as mentioned under the Resetting the board section of the docs?
