How to change the wifi AP credentials on an existing (claimed) node?
hamishcunningham
Postby hamishcunningham » Mon Nov 09, 2020 11:15 am
Hello! Rainmaker looks great, thanks!
One question: I've moved a device to a different location and need to give it new wifi credentials... is there a way to do that without erasing flash and creating a new device?
I tried
$ ./rainmaker.py provision ...node id...
but I get:
Please connect to the wifi PROV_XXXXXX and Press Enter to continue...
(and no AP appears that I can join).
ESP_Piyush
Re: How to change the wifi AP credentials on an existing (claimed) node?
Postby ESP_Piyush » Tue Nov 17, 2020 2:38 pm
Hi Hamish,
If you are using any existing examples, pressing and holding the boot button for more than 3 seconds and then releasing it will reset the Wi-Fi credentials. You can then re-provision from the phone app.
Provisioning from CLI would work for SoftAP provisioning, but the default for ESP32 is BLE provisioning, so you won't find the network PROV_xxxxxx. The reason why CLI has SoftAP provisioning is that we had initially launched ESP RainMaker for ESP32-S2 only, which does not have BLE.
Regards,
Piyush
Cacomixtle
Postby Cacomixtle » Mon Sep 25, 2023 11:34 pm
Hi ESP_Piyush,
I'm looking for an example of how to press and hold the boot button for more than 3 seconds and then release it to perform a specific action. I attempted to use a Semaphore Binary, but occasionally, the interrupt seems to trigger automatically. I think that incorporating a timer for the button holding might resolve this issue.
Any help would be appreciated.
ESP_Piyush
Postby ESP_Piyush » Wed Sep 27, 2023 5:45 pm
You can check the app_reset component of esp-rainmaker/examples/common which is used in all the RainMaker examples.
Users browsing this forum: jetpax and 7 guests
