Deleting RM nodes from RM cloud
myglc2
Postby myglc2 » Fri Aug 28, 2020 5:57 pm
Thank you for a continuing and highly enjoyable ride on RainMaker!
Complements on the awesome functionality, reliability, and really amazing usability. We like to think were are pretty discerning but we really can't find anything to criticize. What a pleasure!
The offline nodes persist in the RM cloud. In normal operation I think this is a good and correct thing.
However, right now our RainMaker App is annoyingly cluttered with offline development nodes.
Is there a way to delete these?
TIA - George
ESP_Piyush
Re: Deleting RM nodes from RM cloud
Postby ESP_Piyush » Sat Aug 29, 2020 12:39 pm
To remove a node from the phone app, tap on the device tile on homepage. Then, in the params screen, tap on the (i) on top right. That will show you the Node details, and a button to remove the node.
Regards,
Piyush.
myglc2
Postby myglc2 » Fri Sep 04, 2020 1:43 am
Hello Piyush & Thank you.
Unfortunately we see no deleter/remove button on "Node Details" page.
SW in use:
Node Details page
Firmware version 1.0
Config version 2020-03-20
iPhone app store
version 2.0.1.
ESP SOC SW commmits
6c17e3a64c02eff3a4f726ce4b7248ce11810833 esp-idf (v4.3-dev-907-g6c17e3a64)
5d664fc2831956d368d1febc3344e83832257c7f esp-rainmaker (heads/master)
Not a crisis, but suggestions would be very welcome. ;-)
TIA, George
ESP_Piyush
Postby ESP_Piyush » Fri Sep 04, 2020 5:52 am
That is strange. Can you share the following:
1) Your iPhone model
2) iOS version
3) Screenshot of the Node details screen.
Regards,
Piyush
myglc2
Postby myglc2 » Fri Sep 04, 2020 3:58 pm
iPhone SE 2020
iOS 13.6.1
TIA - George
Screenshot 2020-09-04 at 11.56.19 AM.jpeg (57.46 KiB) Viewed 11082 times
ESP_Piyush
Postby ESP_Piyush » Fri Sep 04, 2020 4:33 pm
Hi George,
Thanks for sharing the screenshot. There indeed is some rendering issue with iPhone SE. The orange part you see at the bottom is the Remove button. Here is how it shows on iPhone 11.
We will fix this soon, but for the time being, can you check what happens when you tap on that orange part (or remove from some other phone/python CLI)?
Regards,
Piyush
myglc2
Postby myglc2 » Sat Sep 05, 2020 1:29 am
LOL! Thank you Piyush. Yes it did work to tap at the bottom edge. It seems a bit shaky ... with a message something like ... "node does not belong to user." Also, FWIW, it is necessary to close the iPhone SE 2020 app and reopen it when it hangs on the 4 th step. - George
ESP_Piyush
Postby ESP_Piyush » Sat Sep 05, 2020 2:54 am
Hi George,
Do you mean that there are some nodes in your account that you are unable to remove at all, due that "Node does not belong to user" error? Can you share those node_ids?
For the other problem, it could be that the "Ok" button at bottom is similarly getting hidden. Or do you see the button as disabled?
Regards,
Piyush
myglc2
Postby myglc2 » Sun Sep 06, 2020 8:05 am
Sorry I wasn't clear. No problem removing nodes. My point is that the "node does not belong to user" message seems spurious. Thanks. George
Users browsing this forum: No registered users and 8 guests
