Hello ,
I have upload the GPIO example on ESP32 S3 board. I can not show any event on the Dashboard of rainmaker cloud .what should be the reason ?
Event is not Shown on dash board
Re: Event is not Shown on dash board
The query is not clear. What event are you expecting which you are unable to see on the dashboard?
I have attached the Picture . In this picture , Event is 0 you can See properly
another Question:-
I have to send the Data to the Rainmaker cloud by using the MQTT protocol so how can I do that and one more thing where I can See the JSON on Dashboard ?
well I am new for Rainmaker so I can not find proper solution for the same.
Thank you
trupal
another Question:-
Thank you
trupal
- event.png (313.89 KiB) Viewed 27662 times
Insights events will show up only if explicitly reported from your application code using ESP_DIAG_EVENT() function, a sample of which can be found here. There are no "default" events as such.
Meanwhile, JSON payloads for RainMaker are documented here. However, you never need to format/parse the JSONs anywhere as these are handled by the RainMaker core. What exactly are you looking to do?
I have to send 10 device status (ON/OFF) to rainmaker cloud in JSON format !ESP_Piyush wrote: ↑Mon Oct 30, 2023 4:53 pmInsights events will show up only if explicitly reported from your application code using ESP_DIAG_EVENT() function, a sample of which can be found here. There are no "default" events as such.
Thank you
Trupal
It is still not clear why you need JSON format specifically. You can see here that RainMaker allows creating multiple devices under same node. Using esp_rmaker_param_update_and_report() which you can find in all examples, you can report the state of any parameters, including the power/on-off parameter as indicated here.
okay got it.ESP_Piyush wrote: ↑Tue Oct 31, 2023 6:44 amIt is still not clear why you need JSON format specifically. You can see here that RainMaker allows creating multiple devices under same node. Using esp_rmaker_param_update_and_report() which you can find in all examples, you can report the state of any parameters, including the power/on-off parameter as indicated here.
Thank you
Users browsing this forum: AntonKozlenko and 47 guests
