Hello team ,
Can I use ESP RainMaker on ESP32 S3 wroom 1 board? because when I try to upload GPIO example it shown following errors.
Error log :-
I (103182) esp_claim: Starting the Self Claim Process. This may take time.
E (110122) esp_claim: Invalid response for https://esp-claiming.rainmaker.espressi ... aim/verify
E (110122) esp_claim: Status = 400, Data = {"status":"failure","description":"Invalid challenge response"}
E (110132) esp_claim: Claim Verify Failed.
above errors are not shown on other ESP32 boards (Like, ESP32 S3 wroom 2 and wroom 1u as well).
Thank you
Trupal
ESP32 S3 wroom 1 board on ESP Rainmkaer
Re: ESP32 S3 wroom 1 board on ESP Rainmkaer
This can happen only if the board is too old and does not have the secret programmed in the efuse. Can you run this command
and share the output over email at esp-rainmaker-admin@espressif.com. Please do not share this information here on the forum.
espefuse.py summary --port $ESPPORT
Okay ,Thank you for the information. I will send the detail as soon as possible.ESP_Piyush wrote: ↑Mon Oct 30, 2023 5:04 pmThis can happen only if the board is too old and does not have the secret programmed in the efuse. Can you run this command
and share the output over email at esp-rainmaker-admin@espressif.com. Please do not share this information here on the forum.Code: Select all
I have sent the output in mentioned mail. Hope you find well.ESP_Piyush wrote: ↑Mon Oct 30, 2023 5:04 pmThis can happen only if the board is too old and does not have the secret programmed in the efuse. Can you run this command
Can you please check it ?
Thank you
Trupal
Users browsing this forum: No registered users and 73 guests
