[SOLVED] Unit tests are disappeared from VS Code Activiy Bar
kozmotronik
Postby kozmotronik » Tue Feb 11, 2025 7:26 am
Hi there, ESP noob here.
I am trying to create a custom component with its unit tests in VS Code. The test cases were visible in the Activity Bar > Testing section at first. Then suddenly the tests have been disappeared as I keep developing the component. I've tried building and flashing the test app. It did built, but no test listed in the test menu.
Here how it looks in the UI:
Screenshot image
This is how the test menu looks in the terminal output after flashing and monitoring:
Press ENTER to see the list of tests.
Here's the test menu, pick your combo:
Enter test for running.
If the directory structure would be a concern, then the following is the directory structure of the whole project:
custom_component
├── CMakeLists.txt
├── components
│   └── relay_chn
│       ├── CMakeLists.txt
│       ├── idf_component.yml
│       ├── include
│       │   └── relay_chn.h
│       ├── Kconfig
│       ├── relay_chn.c
│       └── test
│           ├── main
│           │   ├── CMakeLists.txt
│           │   ├── relay_chn_test.c
│           │   └── relay_chn_test_main.c
│           └── sdkconfig.defaults
├── main
│   └── main.c
├── README.md
├── sdkconfig
├── sdkconfig.old
└── unity-app
    ├── CMakeLists.txt
    ├── conftest.py
    ├── dependencies.lock
    ├── main
    │   └── test_app_main.c
    ├── sdkconfig
    ├── sdkconfig.defaults
    ├── sdkconfig.old
    └── test_unit_case.py
Update 25-02-14 - Added git repo link
The public git repo link -> https://gitea.kozmotronik.com.tr/Kozmot ... /relay_chn
What should I do to make the tests appear in the Testing tab of the activity bar? I can share the contents of files, or better can make it a public git repo if required. Any kind of help is highly appreciated.
ESP_bignacio
Re: Unit tests are disappeared from VS Code Activiy Bar
Postby ESP_bignacio » Mon Feb 17, 2025 8:47 am
The reason why test don't show in the Testing tabs is because it is not following the naming convention of test files. The extension automatically find tests in files of name test_*.c as described in unit testing documentation
kozmotronik
Postby kozmotronik » Mon Feb 17, 2025 9:09 am
Hello Bignacio, thank you for your answer.
As a matter of fact, I've renamed the test files when I noted the naming convention mentioned in the documentation after I posted this post. Sorry for that I did not update the post accordingly.
This is how my project directory structure looks like at the moment but the extension still does not detect the tests.
$ tree -I build
├── CMakeLists.txt
├── components
│   └── relay_chn
│       ├── include
│       │   └── relay_chn.h
│       ├── Kconfig
│       ├── LICENSE
│       ├── README.md
│       ├── src
│       │   └── relay_chn.c
│       └── test
│           ├── main
│           │   └── test_relay_chn.c
├── main
│   └── main.c
├── README.md
├── sdkconfig
├── sdkconfig.old
└── test
    ├── CMakeLists.txt
    └── main
        ├── CMakeLists.txt
        └── test_relay_chn_main.c
10 directories, 21 files
As you can see, I renamed it as test_relay_chn.c, but still no avail.
Then I added the main level test directory in the intent of createing a similar directory structure of the unit test example. This did not change the situation either. What could be the problem? May be one of the CMakeLists files?
kozmotronik
Postby kozmotronik » Tue Mar 04, 2025 5:43 am
Finally Solved
I finally have the test cases appear in the activity bar testing tab. The problem was my test directory structure which was **/test/main/test_*.c, while it should be **/test/test_*.c. The test file was not in the root test directory.
Hope this help to other noobs that may struggle like me.
Users browsing this forum: Google Adsense [Bot] and 111 guests
