Correct Way to Select the Target Chip in Unit Testing?
Posted: Wed Jan 29, 2025 9:30 am
Hi there!
I am trying to get familiar with ESP-IDF unit testing, using the official unit test example. I've gone through the official unit testing docs and also unit testing docs for the ESP-IDF VSCode Plugin.
As a development board, I use the ESP32-C3-DevKitM-1.
However, I get an error about target configuration when I try to run tests from the vscode activity bar, though the correct target chip selected in the target configuration.
Below is the full error output link:
https://gist.github.com/kozmotronik/5d5 ... c79882a952
Looking at the error output, there is one line that describes the main cause of the error which is:
Am I missing any configuration? Can someone please help? Thank you.2025-01-29 10:34:36 /dev/ttyUSB0 failed to connect: This chip is ESP32-C3 not ESP32. Wrong --chip argument?
