ESP32-C3: debugging is not working
jsmith56x
Postby jsmith56x » Sat Oct 19, 2024 1:10 pm
We have just purchased a card
https://docs.espressif.com/projects/esp ... index.html
I have downloaded and installed Espressif IDE
I have created the 'hello_world' project using 'New/Espressif IDF project'
For debugging I have followed
https://github.com/espressif/idf-eclips ... bugging.md
However the debugging is not working. Here is the log
Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:26)
Licensed under GNU GPL v2
For bug reports, read
Info : only one transport option; autoselecting 'jtag'
Info : esp_usb_jtag: VID set to 0x303a and PID to 0x1001
Info : esp_usb_jtag: capabilities descriptor set to 0x2000
Flashing "C:/Work/ESP32/esp32c3_test/build/bootloader/bootloader.bin" at 0x0
** program_esp input args <0x0 verify> **
Error: esp_usb_jtag: could not find or open device!
Please refer to the troubleshooting guide below to identify the problem.
https://github.com/espressif/openocd-es ... ooting-FAQ
** OpenOCD init failed **
shutdown command invoked
** Flashing Failed **
-1
Started by GNU MCU Eclipse
Error: [esp32c3] Unsupported DTM version: -1
Error: [esp32c3] Could not identify target type.
I have also tried the board in Arduino. The program uploading is working however the debugging is not. I have tried the Arduino program uploading on a real Linux (not VM) with the same result: uploading is working but the debug is not. What I made wrong? Or I have to press BOOT and RESET buttons in a specific order?
With the same cable I can debug an Stm32 MCU on assembly level in Eclipse.
My USB settings
See usb_settings in attachments
VID PID 10C4:EA60
Tried Zadig with no success also.
Please help.
ESP_kondalkolipaka
Re: ESP32-C3: debugging is not working
Postby ESP_kondalkolipaka » Mon Oct 21, 2024 3:24 pm
This tells us that OpenOCD is unable to communicate with your ESP32-C3 board so this could be due to the configuration mismatch in the OpenOCD configuration wizard. Make sure select built-in USB-JTAG like below!
Screenshot 2024-10-21 at 5.22.01 PM.png (299.99 KiB) Viewed 1104 times
Edmundo
Postby Edmundo » Mon Nov 18, 2024 10:35 am
if your ESP board has the same basic electrical struktur as the ESP32-C3-DevKit-02 it only has one USB connector that is located to the UART pads of the ESP32-C3 which enables you to capture the serial output and to download a firmware file.
For using the internal USB Debugger you have to connect the WROOM pads GPIO18 and GPIO19 to usb.
The DevKit-02 (I think your board also) has an jumper area located on the board which must be modified in the way that the existing resistors R1 and R4 must be placed to the R2 and R3 positions (not connected at default).
You have to connect and additional USB-serial device (with level shifter) to the Tx and Rx pins of your board to enable the firmware download.
Edmundo
Hope this helps,
Users browsing this forum: No registered users and 48 guests
