cannot open function declaration
lilarcor
Postby lilarcor » Thu Oct 10, 2024 5:56 am
I installed the latest eclipse-IDE and ran into issue of cannot open declaration of a function.
it prompted a error in the console saying that:
java.io.UncheckedIOException: java.io.IOException: Cannot run program "clangd" (in directory "C:\Espressif\frameworks\esp-idf-v5.3.1"): CreateProcess error=2, The system cannot find the file specified
java.util.concurrent.CompletionException: java.io.UncheckedIOException: java.io.IOException: Cannot run program "clangd" (in directory "C:\Espressif\frameworks\esp-idf-v5.3.1"): CreateProcess error=2, The system cannot find the file specified
at java.base/java.util.concurrent.CompletableFuture.encodeThrowable(CompletableFuture.java:315)
at java.base/java.util.concurrent.CompletableFuture.completeThrowable(CompletableFuture.java:320)
at java.base/java.util.concurrent.CompletableFuture$AsyncSupply.run(CompletableFuture.java:1770)
at java.base/java.lang.Thread.run(Thread.java:833)
I tried reinstalled the software it doesnt help.
Anyone has solution to this?
Thank you
ESP_kondalkolipaka
Re: cannot open function declaration
Postby ESP_kondalkolipaka » Mon Oct 14, 2024 11:38 am
Looks like IDE was unable to figure out the correct clangd path for LSP Editor.
https://github.com/espressif/idf-eclips ... figuration
Could you check the preferences? clangd path should point to the correct clangd executable.
Screenshot 2024-10-14 at 1.35.11 PM.png (550.71 KiB) Viewed 1049 times
Users browsing this forum: No registered users and 31 guests
