I installed a new version of Eclipse following the Get Started Docs.
I am able to import example esp projects and build them with no problem.
I have an old esp project that builds perfectly fine on another computer running an older version of Eclipse with older tool chain; but I couldn't get it to build on a newer version of Eclipse/ESP-IDF. To keep it simple, I wanted to get it to build on the command line first. I was using a newer tool chain v5.4, but because my project was built from v4.3, I had some migration issues to deal with. It took me quite a while modifying the code before I was able to build it with no errors on the command line, but I eventually did.
I imported this working project into eclipse, just like I did with an example project that builds perfectly fine. However, when I hit the build button, I get:
09:02:49 **** Incremental Build of configuration Default for project tempctrl ****
make all
packaging cannot be imported. If you've installed a custom Python then this package is provided separately and have to be installed as well. Please refer to the Get Started section of the ESP-IDF Programming Guide for setting up the required packages.
make: *** No rule to make target 'check_python_dependencies', needed by 'all'. Stop.
"make all" terminated with exit code 2. Build might be incomplete.
09:02:50 Build Failed. 1 errors, 0 warnings. (took 470ms)
I'm thinking it has something to do with something in the path of the project folder, but I haven't a clue. I'd like to be able to use Eclipse, but as of now, it only works at the command line. Any help would be much appreciated.
Existing Imported Project Fails in Eclipse IDE
1101101001001011010110001110011001100010010100010001010001000100101011110
Users browsing this forum: No registered users and 14 guests
