SPI does not work
Posted: Sat Jan 27, 2024 3:49 pm
by Energiya
I have got XIAO ESP32S3 and ESP32-WROOM32 units. I have got exactly the same problem on both. SPI works on Arduino but it does not on ESP-IDF. I use ESP-IDF 5.1.2.
I setup SPI by using code below. Later I send 4 bytes
  1. //On XIAO I tried
  2.         //gpio_iomux_in(GPIO_NUM_9, SPI3_D_IN_IDX);
  3.         //gpio_iomux_out(GPIO_NUM_8, SPI3_Q_OUT_IDX, false);
  4.         //gpio_iomux_in(GPIO_NUM_7, SPI3_CLK_IN_IDX);
  5.         //gpio_iomux_in(GPIO_NUM_1, SPI3_CS0_IN_IDX);
  6.         // and this
  7.         //gpio_iomux_out(GPIO_NUM_9, SPI3_D_OUT_IDX, false);
  8.         //gpio_iomux_in(GPIO_NUM_8, SPI3_Q_IN_IDX);
  9.         //gpio_iomux_out(GPIO_NUM_7, SPI3_CLK_OUT_IDX, false);
  10.         //gpio_iomux_out(GPIO_NUM_1, SPI3_CS0_IN_IDX,false);
  11.
  12.         spi_bus_config_t Config;
  13.         Config.mosi_io_num = GPIO_NUM_23;//GPIO_NUM_9;//GPIO_NUM_13;//
  14.         Config.miso_io_num = GPIO_NUM_19;//GPIO_NUM_8;//GPIO_NUM_12;//
  15.         Config.sclk_io_num = GPIO_NUM_18;//GPIO_NUM_7;//GPIO_NUM_14;//;
  16.         //Config.mosi_io_num = GPIO_NUM_9;
  17.         //Config.miso_io_num = GPIO_NUM_8;
  18.         //Config.sclk_io_num = GPIO_NUM_7;
  19.         Config.max_transfer_sz = 0;
  20.         Config.quadwp_io_num = -1;  // -1 not used
  21.         Config.quadhd_io_num = -1;  // -1 not used
  22.         Config.intr_flags = 0;
  23.         Config.data0_io_num = -1;
  24.         Config.data1_io_num = -1;
  25.         Config.data2_io_num = -1;
  26.         Config.data3_io_num = -1;
  27.         Config.data4_io_num = -1;
  28.         Config.data5_io_num = -1;
  29.         Config.data6_io_num = -1;
  30.         Config.data7_io_num = -1;
  31.         //Tried with SPICOMMON_BUSFLAG_NATIVE_PINS, SPICOMMON_BUSFLAG_NATIVE_PINS, SPICOMMON_BUSFLAG_GPIO_PINS
  32.         Config.flags = SPICOMMON_BUSFLAG_MASTER;// | SPICOMMON_BUSFLAG_NATIVE_PINS;// | SPICOMMON_BUSFLAG_MISO | SPICOMMON_BUSFLAG_MOSI;
  33.         Config.isr_cpu_id = INTR_CPU_ID_0;
  34.         if(ESP_OK == spi_bus_initialize(SPI3_HOST, &Config, SPI_DMA_CH_AUTO))//SPI_DMA_DISABLED);//SPI_DMA_CH_AUTO);
  35.         {
  36.             printf("-----OK-----");
  37.         }
  38.
  39.         //spicommon_bus_initialize_io
  40.         spi_device_interface_config_t ConfigInterface;
  41.         ConfigInterface.command_bits = 0;
  42.         ConfigInterface.address_bits = 0;
  43.         ConfigInterface.dummy_bits = 0;
  44.         ConfigInterface.mode = 0;
  45.         ConfigInterface.duty_cycle_pos = 128;  // default 128 = 50%/50% duty
  46.         ConfigInterface.cs_ena_pretrans = 0;  // 0 not used
  47.         ConfigInterface.cs_ena_posttrans = 0;  // 0 not used
  48.         ConfigInterface.clock_speed_hz = 500000;
  49.         ConfigInterface.clock_source = SPI_CLK_SRC_APB; //SPI_CLK_SRC_DEFAULT
  50.         ConfigInterface.spics_io_num = GPIO_NUM_5;
  51.         ConfigInterface.flags = 0;//SPI_DEVICE_HALFDUPLEX | SPI_DEVICE_NO_DUMMY; //| SPI_DEVICE_HALFDUPLEX;
  52.         ConfigInterface.queue_size = 1;
  53.         ConfigInterface.pre_cb = NULL;
  54.         ConfigInterface.post_cb = NULL;
  55.         ConfigInterface.input_delay_ns = 0;
  56.         if(ESP_OK == spi_bus_add_device(SPI3_HOST, &ConfigInterface, &SPIHandle))
  57.         {
  58.             printf("-----OK-----");
  59.         }
I receive wrong data, always the same bytes no matter what 4 bytes are sent. Screenshot from logic analyzer:
When I use Arduino
  1. #include <Arduino.h>
  2. #include <SPI.h>
  3.
  4. #define VSPI_MISO   19
  5. #define VSPI_MOSI   23
  6. #define VSPI_SCLK   18
  7. #define VSPI_SS     5
  8.
  9. SPIClass * vspi = NULL;
  10.
  11. void setup()
  12. {
  13.   printf("Start");
  14.   pinMode(VSPI_SS, OUTPUT);
  15.   vspi = new SPIClass(2);
  16.   vspi->begin(VSPI_SCLK, VSPI_MISO, VSPI_MOSI, VSPI_SS); //SCLK, MISO, MOSI, SS
  17. }
  18.
  19. void loop()
  20. {
  21.   //uint16_t addressToRead = 0x0740;
  22.   uint16_t addressToRead = 0x08E7;
  23.   vspi->beginTransaction(SPISettings(500000, MSBFIRST, SPI_MODE0));
  24.   delay(10);
  25.   digitalWrite(VSPI_SS, 0);
  26.   vspi->transfer(0x0D);
  27.   vspi->transfer16(addressToRead);
  28.   vspi->transfer(0x38);
  29.   digitalWrite(VSPI_SS, 1);
  30.   vspi->endTransaction();
  31.
  32. delay(2000);
  33.
  34.   vspi->beginTransaction(SPISettings(500000, MSBFIRST, SPI_MODE0));
  35.   delay(10);
  36.   addressToRead = 0x08E7;
  37.   digitalWrite(VSPI_SS, 0);
  38.   vspi->transfer(0x1D);
  39.   vspi->transfer16(addressToRead);
  40.   vspi->transfer(0x00);
  41.   uint8_t regValue = vspi->transfer(0x00);
  42.   digitalWrite(VSPI_SS, 1);
  43.   vspi->endTransaction();
  44.   printf("Reg %u", regValue);
  45.   delay(2000);
  46.   printf("Stop\n");
  47. }
Everything is correct. I can write and read data without problems. Screenshot from logic analyzer below. Everything is fine.
When I start program on Arduino later on ESP-IDF you can clearly see differences on logic analyzer
Hardware connection is fine because it works on Arduino. It is something wrong with configuration on ESP-IDF (I have spent lots of time trying different configurations). It is something incorrect with PINS or MOSI or CLOCK or ... . Behavior is the same on XIAO ESP32s3 and ESP32 units ( I reconfigure pins of course ). Tried VSPI and HSPI.
Did someone have similar issue?
Re: SPI does not work
Posted: Sun Jan 28, 2024 4:37 pm
by Energiya
I have resolved the issue. I have noticed that mosi_io_num and data0_io_num are union. Also miso_io_num and data1_io_num.
union {
int mosi_io_num; ///< GPIO pin for Master Out Slave In (=spi_d) signal, or -1 if not used.
int data0_io_num; ///< GPIO pin for spi data0 signal in quad/octal mode, or -1 if not used.
union {
int miso_io_num; ///< GPIO pin for Master In Slave Out (=spi_q) signal, or -1 if not used.
int data1_io_num; ///< GPIO pin for spi data1 signal in quad/octal mode, or -1 if not used.
When these lines are removed everything works fine
