can't setp idf in vscode
Posted: Tue Nov 08, 2022 7:48 am
by led_idf
it stopped here
Installing ESP-IDF extension python packages in H:\Espressif\python_env\idf4.4_py3.8_env\Scripts\python.exe ...
Looking in indexes: https://pypi.tuna.tsinghua.edu.cn/simple
Requirement already satisfied: gcovr in h:\espressif\python_env\idf4.4_py3.8_env\lib\site-packages (from -r c:\Users\leomsfs\.vscode\extensions\espressif.esp-idf-extension-1.5.1\requirements.txt (line 1)) (5.2)
Requirement already satisfied: idf-component-manager in h:\espressif\python_env\idf4.4_py3.8_env\lib\site-packages (from -r c:\Users\leomsfs\.vscode\extensions\espressif.esp-idf-extension-1.5.1\requirements.txt (line 2)) (1.1.4)
Requirement already satisfied: websocket_client in h:\espressif\python_env\idf4.4_py3.8_env\lib\site-packages (from -r c:\Users\leomsfs\.vscode\extensions\espressif.esp-idf-extension-1.5.1\requirements.txt (line 3)) (1.4.2)
Requirement already satisfied: lxml in h:\espressif\python_env\idf4.4_py3.8_env\lib\site-packages (from gcovr->-r c:\Users\leomsfs\.vscode\extensions\espressif.esp-idf-extension-1.5.1\requirements.txt (line 1)) (4.9.1)
Requirement already satisfied: jinja2 in h:\espressif\python_env\idf4.4_py3.8_env\lib\site-packages (from gcovr->-r c:\Users\leomsfs\.vscode\extensions\espressif.esp-idf-extension-1.5.1\requirements.txt (line 1)) (3.0.3)
Requirement already satisfied: pygments in h:\espressif\python_env\idf4.4_py3.8_env\lib\site-packages (from gcovr->-r c:\Users\leomsfs\.vscode\extensions\espressif.esp-idf-extension-1.5.1\requirements.txt (line 1)) (2.13.0)
Requirement already satisfied: contextlib2>0.6.0 in h:\espressif\python_env\idf4.4_py3.8_env\lib\site-packages (from idf-component-manager->-r c:\Users\leomsfs\.vscode\extensions\espressif.esp-idf-extension-1.5.1\requirements.txt (line 2)) (21.6.0)
Requirement already satisfied: colorama in h:\espressif\python_env\idf4.4_py3.8_env\lib\site-packages (from idf-component-manager->-r c:\Users\leomsfs\.vscode\extensions\espressif.esp-idf-extension-1.5.1\requirements.txt (line 2)) (0.4.6)
Requirement already satisfied: pyyaml>5.2 in h:\espressif\python_env\idf4.4_py3.8_env\lib\site-packages (from idf-component-manager->-r c:\Users\leomsfs\.vscode\extensions\espressif.esp-idf-extension-1.5.1\requirements.txt (line 2)) (6.0)
Requirement already satisfied: six in h:\espressif\python_env\idf4.4_py3.8_env\lib\site-packages (from idf-component-manager->-r c:\Users\leomsfs\.vscode\extensions\espressif.esp-idf-extension-1.5.1\requirements.txt (line 2)) (1.16.0)
Requirement already satisfied: schema in h:\espressif\python_env\idf4.4_py3.8_env\lib\site-packages (from idf-component-manager->-r c:\Users\leomsfs\.vscode\extensions\espressif.esp-idf-extension-1.5.1\requirements.txt (line 2)) (0.7.5)
Requirement already satisfied: requests-toolbelt in h:\espressif\python_env\idf4.4_py3.8_env\lib\site-packages (from idf-component-manager->-r c:\Users\leomsfs\.vscode\extensions\espressif.esp-idf-extension-1.5.1\requirements.txt (line 2)) (0.10.1)
Requirement already satisfied: tqdm<5 in h:\espressif\python_env\idf4.4_py3.8_env\lib\site-packages (from idf-component-manager->-r c:\Users\leomsfs\.vscode\extensions\espressif.esp-idf-extension-1.5.1\requirements.txt (line 2)) (4.64.1)
Requirement already satisfied: future in h:\espressif\python_env\idf4.4_py3.8_env\lib\site-packages (from idf-component-manager->-r c:\Users\leomsfs\.vscode\extensions\espressif.esp-idf-extension-1.5.1\requirements.txt (line 2)) (0.18.2)
Requirement already satisfied: click>=8.0.0 in h:\espressif\python_env\idf4.4_py3.8_env\lib\site-packages (from idf-component-manager->-r c:\Users\leomsfs\.vscode\extensions\espressif.esp-idf-extension-1.5.1\requirements.txt (line 2)) (8.0.4)
Requirement already satisfied: requests<3 in h:\espressif\python_env\idf4.4_py3.8_env\lib\site-packages (from idf-component-manager->-r c:\Users\leomsfs\.vscode\extensions\espressif.esp-idf-extension-1.5.1\requirements.txt (line 2)) (2.28.1)
Requirement already satisfied: charset-normalizer<3,>=2 in h:\espressif\python_env\idf4.4_py3.8_env\lib\site-packages (from requests<3->idf-component-manager->-r c:\Users\leomsfs\.vscode\extensions\espressif.esp-idf-extension-1.5.1\requirements.txt (line 2)) (2.1.1)
Requirement already satisfied: idna<4,>=2.5 in h:\espressif\python_env\idf4.4_py3.8_env\lib\site-packages (from requests<3->idf-component-manager->-r c:\Users\leomsfs\.vscode\extensions\espressif.esp-idf-extension-1.5.1\requirements.txt (line 2)) (3.4)
Requirement already satisfied: certifi>=2017.4.17 in h:\espressif\python_env\idf4.4_py3.8_env\lib\site-packages (from requests<3->idf-component-manager->-r c:\Users\leomsfs\.vscode\extensions\espressif.esp-idf-extension-1.5.1\requirements.txt (line 2)) (2022.9.24)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in h:\espressif\python_env\idf4.4_py3.8_env\lib\site-packages (from requests<3->idf-component-manager->-r c:\Users\leomsfs\.vscode\extensions\espressif.esp-idf-extension-1.5.1\requirements.txt (line 2)) (1.26.12)
Requirement already satisfied: MarkupSafe>=2.0 in h:\espressif\python_env\idf4.4_py3.8_env\lib\site-packages (from jinja2->gcovr->-r c:\Users\leomsfs\.vscode\extensions\espressif.esp-idf-extension-1.5.1\requirements.txt (line 1)) (2.1.1)
WARNING: You are using pip version 20.3.3; however, version 22.3.1 is available.
You should consider upgrading via the 'H:\Espressif\python_env\idf4.4_py3.8_env\Scripts\python.exe -m pip install --upgrade pip' command.
Installing ESP-IDF Debug Adapter python packages in H:\Espressif\python_env\idf4.4_py3.8_env\Scripts\python.exe ...
and the error shows no python.h can't find this file
how to fix it?
Re: can't setp idf in vscode
Posted: Thu Nov 10, 2022 4:12 am
by ESP_bignacio
Could you share the troubleshooting information?
https://github.com/espressif/vscode-esp ... leshooting
