Hello ESPRESSIF
I use vscode and IDF Extension and ESP32C3
I want to use two sample code for two esp for BLE5 test so The Problem is when I change COMx port in vscode to COMy port
in button left side the COM port doesn't change so I have to use ESP-IDF Terminal and use command :
idf.py -p COM29 flash
or
idf.py -p COM28 flash
vscode IDF UI COM port Change sometime dont work and sometime work correctly
VSCode COM Port dont change sometime
- vscode COM port.jpg (397.01 KiB) Viewed 7572 times
Re: VSCode COM Port dont change sometime
Have you defined the COM port at the settings.json file (inside .vscode folder)?
Something like this:
You can try to remove this line if you want to select manually the COM port in your project.
"idf.port": "/dev/ttyUSB0",
Users browsing this forum: No registered users and 51 guests
