I have the latest vscode version and esp-idf as well as the esp-idf extension.
When creating the arduino as a component project within the IDE I get the new code ok but the main arduino.h file is not found.
Do I have to manually copy this or change a path or something to get the template created to compile?
Arduino as a component create from extension
Re: Arduino as a component create from extension
You might need to configure the c_cpp_properties.json to work with it.
Also check here https://docs.espressif.com/projects/ard ... onent.html
Users browsing this forum: No registered users and 11 guests
