ESP-IDF + VsCode Config - Highlight
mm_1993
Postby mm_1993 » Mon Sep 13, 2021 7:20 am
Hi everyone
I wanna know what should I do to enable
#ifndef something
some highlighted code .....
#endif
the code between #if or #ifndef value that not defined be in highlight
when I add .vscode folders and c_cpp_properties.json file make it disable
like these two photos :
before add .json file :
and after add .json file (folder .vscode top-left side in photo) :
thank you
mm_1993
Re: ESP-IDF + VsCode Config - Highlight
Postby mm_1993 » Tue Nov 02, 2021 6:56 am
Hello again
anyone know how to active this feature ?
How can I setup highlighting of code that has been deactivated via a #ifdef in vs code idf.
test highlight.jpg (10.79 KiB) Viewed 4541 times
Users browsing this forum: No registered users and 49 guests
