VS Code Windows does not recognize esptool, while esptool is available in VS Code terminal
espdorian
Postby espdorian » Mon Dec 28, 2020 11:17 am
I've installed VS code 1.52.1 with IDF plugin 0.5.1
I start code from an IDF command prompt, so all environment variables are correct ( is there another way to start code directly ? )
From the VS Code terminal esptool works:
esptool version
esptool.py v3.0
3.0
However when selecting "flash device" : "Make sure you have the esptool.py installed and set in $PATH with proper permission"
I could not find any setting in VS Code related to esptool.
Where to look ?
espdorian
Re: VS Code Windows does not recognize esptool, while esptool is available in VS Code terminal
Postby espdorian » Mon Dec 28, 2020 2:33 pm
This might be related to my next topic, which seem to mix some Python versions.
ESP_bignacio
Postby ESP_bignacio » Tue Dec 29, 2020 7:03 am
Have you configure the extension using the ESP-IDF: Configure ESP-IDF extension command ?
Steps are explained here : https://github.com/espressif/vscode-esp ... OARDING.md
or check our Youtube video
espdorian
Postby espdorian » Tue Dec 29, 2020 9:36 am
Reinstalling the tools (esp-idf-tools-setup-2.3.exe) finally solved the issue. :)
Users browsing this forum: No registered users and 19 guests
