VSC extension and Arduino as component
Posted: Wed Apr 15, 2020 9:53 am
by edouardreg
I want to use Arduino as component (I use VSC extension with windows 10). In the GUI configuration I don't see the Arduino option we can have in make menuconfig ?
If I try to launch menuconfig, then a message say : "IDF_PATH environment variable needs to be set to use this tool". Need to set it or is there an other better way to set arduino options ?
Also If you have a tutorial to use Arduino as a component in this context (vsc extension windwos 10) : you are welcome as the explanations here : https://github.com/espressif/arduino-es ... builder.md
don't speak clearly to me...For example : is the master branch of Arduino core compatible with IDFv4 ? Will the Arduino libraries appears in the ">PROJECT COMPONENTS" of VSC and how add then an addafruit Arduino library for example (need to compile something again or not) ?
Thanks !
Ed
Re: VSC extension and Arduino as component
Posted: Tue Jun 16, 2020 6:56 am
by ESP_bignacio
Please give a try to the feature PR to support this https://github.com/espressif/vscode-esp ... n/pull/117
