Not able to launch GDB in IDF v4.4
I recently updated my IDF and .espressif folder to the latest stable configuration, IDF v4.4 but when I try to run the source level debugging enviroment is not possible. When I execute it in VS code, is able to launch the OpenOCD stage but seems is not able to launch GDB, this is what I get:
when normally it continues up to having the GDB enviroment. After some investigation, I noticed that from IDF v4.3.2 to v4.4 the xtensa version changed to esp-2021r2-patch2-8.4.0 and doesn't include a "xtensa-esp32-elf-gdb" folder as the previews version. I'm wondering that this could be the reason as the application is not finding it but any comment will be appreciated.
sch0bert
sch0bert
Re: Not able to launch GDB in IDF v4.4
Hello community,
Any idea where could this folder be or what's going on?
Really appreciate your comments.
Regards,
sch0bert
Regards,
sch0bert
Moving this to the IDE subforum as I suspect it's a thing with the VSCode integration.
Hi
seem like a my problem ... but i use esp-idf 4.3 ... and afther the end of dicember everything worked perfectl ...
now the log is
now the log is
Open On-Chip Debugger v0.10.0-esp32-20210401 (2021-04-01-15:46)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 2
adapter speed: 20000 kHz
❌ Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : esp32.cpu0: Debug controller was reset.
Info : esp32.cpu0: Core was reset.
Info : esp32.cpu1: Debug controller was reset.
Info : esp32.cpu1: Core was reset.
Info : accepting 'tcl' connection on tcp/6666
Info : dropped 'tcl' connection
Are you using ESP-IDF VSCode Extension v1.3 ?
(VSCode's default behavior is to automatically update.)
1. Does using F1 "ESP-IDF: Flash (with JTag)" succeed in programming the ESP32?
2. Does reverting the ESP-IDF VSCode Extension from v1.3 to v1.2, then launching the debugger, succeed?
The following thread may be related.
https://www.esp32.com/viewtopic.php?f=40&t=25838#p91227
Yes mi problem was realtive to Espressif IDF version 1.3, it's not works with jtag and the 1.2 instead yes.
I sudgest to downgrade the version of the Espressif IDF on VS code.
In my case I don't think this is related to the VS ESP extension as it used to work with IDF v4.3.2 and extension v1.3, it stopped working since I updated to IDF v4.4 as the xtensa version changed to esp-2021r2-patch2-8.4.0 and doesn't include a "xtensa-esp32-elf-gdb" folder as the previews version.
Schobert, I'm using ESP-IDF v4.4 with ESP-IDF VSCode Extension 1.3,
and despite your nice observation of the lack of the "xtensa-esp32-elf-gdb" folder,
it starts debugging fine, so that doesn't seem to be a cause.
With your present setup ( ESP-IDF v4.4 with ESP-IDF VSCode Extension 1.3),
does using
VSCode makes it easy to revert to v1.2 of the ESP-IDF VSCode Extension.
Does reverting the Extension from v1.3 to v1.2 (still using ESP-IDF v4.4),
succeed?
Does F1 "ESP-IDF: Flash (with JTag)"
does using
succeed?
See https://github.com/espressif/vscode-esp ... issues/623 for more info and fixes.
Users browsing this forum: No registered users and 12 guests
