I installed the vscode extension for esp32 but when I want to see the examples, when asking for the framework, VS Code cannot find it.
I wanted to use the frame by entering esp-idf: contiguration, but only Welcome appears.
restart Visual Studio Code and run this wizard again, and I can't use it.
Could anyone help me please?
problems with esp-idf framework in vs code
Re: problems with esp-idf framework in vs code
There is an issue in Windows that should be fixed in GitHub master.
Could you try this vsix installer https://nightly.link/espressif/vscode-e ... 655771.zip and see if the issue is fixed ?
ESP_bignacio wrote: ↑Thu Jan 13, 2022 11:19 amThere is an issue in Windows that should be fixed in GitHub master.
Thank you very much, it worked by installing it as you told me, you are the best
Users browsing this forum: No registered users and 17 guests
