(solved) getting VSCode to use a specific IDF
mzimmers
Postby mzimmers » Fri Oct 22, 2021 11:05 pm
Hi all -
When I began with VS Code and the IDF plugin, my IDF was located in $HOME/esp/esp-idf. I've since downloaded v4.3.1 (using git clone), and would like to use this version. I've tried to make the change in the extension setup, but I'm still using the original version. (I say this because if I focus on a reference to an IDF routine, and hit F12, it opens the file in the original location.)
What have I forgotten?
Thanks...
ESP_bignacio
Re: getting VSCode to use a specific IDF
Postby ESP_bignacio » Mon Oct 25, 2021 10:05 am
Check if your project directory has a `.vscode/settings.json` file with configuration settings such as `idf.espIdfPath` overriding the user level settings.
Make sure to:
1) Choose Select where to save configuration settings command and choose the workspace folder to save the settings.
2) Or `.vscode/settings.json` settings that are overriding user level settings
Here is the documentation about settings precedence: https://github.com/espressif/vscode-esp ... ROJECTS.md
mzimmers
Postby mzimmers » Mon Oct 25, 2021 2:33 pm
Hi bignacio -
Yes, that was the problem exactly. I removed that line from my settings.json file, (had to do a clean to empty the cmake cache) and rebuilt...I'm now picking up the right repository. Thanks for the help.
Users browsing this forum: No registered users and 59 guests
