Problems with VSCode ESP-IDF externsion
lg.lindstrom
Postby lg.lindstrom » Thu Oct 07, 2021 6:33 pm
This is quite annoying for me. Sometimes ESP-IDF extension for VsCode stops working and all kind of strange errors turns up. Not always but sometimes,, and I can't see a clear way to avoid those errors.
1) Menyconfig hangs on startup. After issue the command to start it hangs as shown by picture below.
menuconfig problem.PNG (8.52 KiB) Viewed 4401 times
2) Command "Full clean Project" don't work. Can't find build folder.
3) Cmake is not happy
 [kit] Successfully loaded 4 kits from C:\Users\lglin\AppData\Local\CMakeTools\cmake-tools-kits.json
[main] Unable to determine what CMake generator to use. Please install or configure a preferred generator, or update settings.json, your Kit configuration or PATH variable. Error: No usable generator found.
[main] Configuring folder: idf-mdbc
no build directory.PNG (5.7 KiB) Viewed 4401 times
ESP_bignacio
Re: Problems with VSCode ESP-IDF externsion
Postby ESP_bignacio » Fri Oct 08, 2021 12:17 pm
Can you share the content of https://github.com/espressif/vscode-esp ... leshooting
There should be a SDK Configuration Editor output in Menu view -> Output or some error printed in the log specified in the previous link.
Users browsing this forum: No registered users and 18 guests
