ESP-IDF VS Code extension build suddenly failing (macOS)
TinkerBearNZ
Postby TinkerBearNZ » Sat Mar 06, 2021 3:08 am
macOS just updated to 11.2.2 (at least I think that's the change responsible), and now if I try to build from the icon at the bottom of the VS Code window, I get an immediate failure:
> Executing task: espressif.esp-idf-extension: ESP-IDF Compile <
ESP-IDF Custom Terminal
$ cmake
spawn cmake EACCES
Running "idf.py build" still works fine - even in the VS Code terminal.
I suspect Apple may have changed their sandboxing permissions, but don't know what to look for.
astate
Re: ESP-IDF VS Code extension build suddenly failing (macOS)
Postby astate » Sat Mar 06, 2021 3:08 pm
I have the same issue running Mac OS 11.1
Any solution yet?
eqon133
Postby eqon133 » Sat Mar 06, 2021 6:23 pm
i have exactly same problem this morning. Running macOS Catalina 10.15.7
Alexvrs
Postby Alexvrs » Sat Mar 06, 2021 6:23 pm
I have the same problem, please help!
kristian32
Postby kristian32 » Sat Mar 06, 2021 7:16 pm
Same issue here, but I am on 11.2.1 :( hope we find a solution soon
espshio
Postby espshio » Sun Mar 07, 2021 12:33 am
I had the same issue after updating VSCode 1.54.1.
When I revert back to 1.53.2, it works.
However, I'm not sure what changes will affect them.
ESP_bignacio
Postby ESP_bignacio » Mon Mar 08, 2021 6:55 am
Hi guys apparently this is broken in the latest vscode version, we should have a fix already in GitHub master and will release a new version in marketplace soon.
In the meantime, maybe you can try using the GitHub master VSIX installer here ?
Alexvrs
Postby Alexvrs » Mon Mar 08, 2021 7:21 pm
Thank You Very Much, It Has Crossed! :P
KT819GM
Postby KT819GM » Wed Mar 10, 2021 2:37 pm
Hello, VSIX installer not available anymore? Same problem as OP had, just link not working anymore.
Thank you
KT819GM
Postby KT819GM » Wed Mar 10, 2021 2:53 pm
As my previous post had to be confirmed, writing one more - compiled from source and all is ok now, so please ignore request. Thank you
Users browsing this forum: No registered users and 11 guests
