Symbol not found in eclipse
dariensavio
Postby dariensavio » Fri Jan 08, 2021 12:17 pm
I have installed the plugin in Eclipse for embedded C/C++ developers. The project is building successfully with no errors or warning, but there are several problems of the type "Symbol XXX could not be resolved". sdkconfig.h has been included in the project. What is the solution to this?
Screenshot from 2021-01-08 17-46-53.png (356.11 KiB) Viewed 2698 times
ESP_kondalkolipaka
Re: Symbol not found in eclipse
Postby ESP_kondalkolipaka » Fri Jan 29, 2021 10:14 am
See if this helps.
Project > C/C++ Index > Freshen All Files
If you still see the issue, remove the build directory and re-build the project.
Users browsing this forum: No registered users and 22 guests
