ESP-IDF VSC Extension, set upload baud rate
username
Postby username » Fri Sep 11, 2020 5:01 pm
When flashing the device the default baud rate is 115200. I want to change it to 1152000.
I press F1 then select ESP-IDF- Device Configuration. From there i select Baud Rate, and enter in 1152000.
This does not change the upload rate, nor does it change the monitor baud rate to 1152000, so what does this setting do?
Also, can you guys please change the color scheme for IDF menuconfig, that White background with light gray text is the worst colors to choose.
Re: ESP-IDF VSC Extension, set upload baud rate
Postby ESP_Sprite » Sun Sep 13, 2020 8:35 am
1152000 is not a standard baudrate; possibly your OS or serial driver doesn't like it. Perhaps try 1000000, as it's a bit more standard.
ESP_krzychb
Contact:
Postby ESP_krzychb » Sun Sep 13, 2020 2:03 pm
It looks like a bug. In the meantime I was able to change the rate by adding extra entry in "settings.json":
username
Postby username » Sun Sep 13, 2020 2:46 pm
Thank you that worked. On the "official" ESP32 modules I have used 1152000 works. On others it's to fast.
ESP_Soumesh
Postby ESP_Soumesh » Wed Sep 23, 2020 7:01 am
This is a bug caused from vs code side due to certain behaviours change, we have a fix and will release this ASAP.
Thanks for reporting this bug, we have found the root cause and are working towards a fix, will also make this available ASAP.
Update: The baudrate bug is fixed and released in v0.5.0
username
Postby username » Wed Sep 23, 2020 12:38 pm
Thanks for the update. There is another bug. After you have flashed the part, and open the serial terminal. Make some changes to your code, recompile, and go to flash again it cant because the serial terminal is still open. When you flash, it should first check if the terminal is open, close it, then flash and re-connect again. This is what PlatformIO does, which is super nice.
ESP_Soumesh
Postby ESP_Soumesh » Tue Sep 29, 2020 7:48 am
This is not a bug, but thanks for the feature/behaviours request, we have added this to our pipeline and will be working on this and release this, you can track the further development on this here: https://github.com/espressif/vscode-esp ... issues/182
ESP_Soumesh
Postby ESP_Soumesh » Tue Sep 29, 2020 5:24 pm
After analysis we found that this feature is already there and if you're using idf monitor inside vscode and trigger flash from vscode it will close the monitor and then only start flashing...
If this is not working please open a bug report here: https://github.com/espressif/vscode-esp ... new/choose
username
Postby username » Tue Sep 29, 2020 5:28 pm
But it does not reopen the monitor after the flash.
ESP_Soumesh
Postby ESP_Soumesh » Wed Sep 30, 2020 7:35 am
Thats because we don't store the state of the monitor and flash should only flash and not open monitor, if you want please use the Build, Flash and start a monitor on your device command, which trigger build -> flash -> monitor
More info here: https://github.com/espressif/vscode-esp ... e-commands
Users browsing this forum: No registered users and 10 guests
