I am using a ESP32 Wrover Dev Kit. I want to be able to debug the application on Eclipse IDE.
I have followed the thread.
https://docs.espressif.com/projects/esp ... er-eclipse
Now am able to Build from eclipse. Debugging is enabled - i can see the control stops at breakpoints and i can also see the variable status. But the source code is not mapped - as in, i can see the control stop at breakpoint by debug console but there is no breakpoint hit on the source code. Also when i use "Step Over" Or "Step Into" while Debugging everything happens but not visible through the source window.
What did i miss.
Any help is appreciated.
Regards,
Ram.
Elcipse IDE Debugging - Source code not mapped
Users browsing this forum: No registered users and 11 guests
