I can not build any project even examples on my desktop windows 11 machine. I installed Espressif-IDE, git, python(esp-idf does not require installation of git and python anymore). I create sample project from network/bridge. But I couldn't succeed to build the project. Can you help me out please?
Thanks in advance.
First build gives following error;
Building in: C:\Users\Misafir\workspace\bridge\build
Configuring in: C:\Users\Misafir\workspace\bridge\build
cmake -G Ninja -DCMAKE_TOOLCHAIN_FILE=C:\Espressif\frameworks\esp-idf-v5.2.2\tools\cmake\toolchain-esp32.cmake -DCMAKE_EXPORT_COMPILE_COMMANDS=ON -DCCACHE_ENABLE=1 -DIDF_TARGET=esp32 C:\Users\Misafir\workspace\bridge
-- Found Git: C:/Program Files/Git/cmd/git.exe (found version "2.45.2.windows.1")
-- ccache will be used for faster recompilation
-- The C compiler identification is GNU 13.2.0
-- The CXX compiler identification is GNU 13.2.0
-- The ASM compiler identification is GNU
-- Found assembler: C:/Espressif/tools/xtensa-esp-elf/esp-13.2.0_20230928/xtensa-esp-elf/bin/xtensa-esp32-elf-gcc.exe
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: C:/Espressif/tools/xtensa-esp-elf/esp-13.2.0_20230928/xtensa-esp-elf/bin/xtensa-esp32-elf-gcc.exe - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: C:/Espressif/tools/xtensa-esp-elf/esp-13.2.0_20230928/xtensa-esp-elf/bin/xtensa-esp32-elf-g++.exe - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- git rev-parse returned 'fatal: not a git repository (or any of the parent directories): .git'
-- Could not use 'git describe' to determine PROJECT_VER.
-- Building ESP-IDF components for target esp32
-- Checking Python dependencies...
Constraint file: C:\Espressif\espidf.constraints.v5.2.txt
Requirement files:
- C:/Espressif/frameworks/esp-idf-v5.2.2/tools\requirements\requirements.core.txt
Python being checked: C:\Espressif\python_env\idf5.2_py3.11_env\Scripts\python.exe
Python requirements are satisfied.
Dependencies lock doesn't exist, solving dependencies.
Using component placed at C:\Espressif\frameworks\esp-idf-v5.2.2\examples\ethernet\basic\components\ethernet_init for dependency ethernet_init(*), specified in C:/Users/Misafir/workspace/bridge/main\idf_component.yml
.Updating lock file at C:\Users\Misafir\workspace\bridge\dependencies.lock
Processing 2 dependencies:
[1/2] ethernet_init (*)
[2/2] idf (5.2.2)
-- Project sdkconfig file C:/Users/Misafir/workspace/bridge/sdkconfig
Loading defaults file C:/Users/Misafir/workspace/bridge/sdkconfig.defaults...
-- Compiler supported targets: xtensa-esp-elf
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of time_t
-- Check size of time_t - done
-- Found Python3: C:/Users/Misafir/AppData/Local/Programs/Python/Python312/python.exe (found version "3.12.4") found components: Interpreter
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
-- Found Threads: TRUE
-- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS
-- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS - Success
-- App "bridge" version: 1
-- Adding linker script C:/Users/Misafir/workspace/bridge/build/esp-idf/esp_system/ld/memory.ld
-- Adding linker script C:/Users/Misafir/workspace/bridge/build/esp-idf/esp_system/ld/sections.ld.in
-- Adding linker script C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_rom/esp32/ld/esp32.rom.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_rom/esp32/ld/esp32.rom.api.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_rom/esp32/ld/esp32.rom.libgcc.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_rom/esp32/ld/esp32.rom.newlib-data.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_rom/esp32/ld/esp32.rom.syscalls.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_rom/esp32/ld/esp32.rom.newlib-funcs.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v5.2.2/components/soc/esp32/ld/esp32.peripherals.ld
-- Components: app_trace app_update bootloader bootloader_support bt cmock console cxx driver efuse esp-tls esp_adc esp_app_format esp_bootloader_format esp_coex esp_common esp_eth esp_event esp_gdbstub esp_hid esp_http_client esp_http_server esp_https_ota esp_https_server esp_hw_support esp_lcd esp_local_ctrl esp_mm esp_netif esp_netif_stack esp_partition esp_phy esp_pm esp_psram esp_ringbuf esp_rom esp_system esp_timer esp_wifi espcoredump esptool_py ethernet_init fatfs freertos hal heap http_parser idf_test ieee802154 json log lwip main mbedtls mqtt newlib nvs_flash nvs_sec_provider openthread partition_table perfmon protobuf-c protocomm pthread sdmmc soc spi_flash spiffs tcp_transport ulp unity usb vfs wear_levelling wifi_provisioning wpa_supplicant xtensa
-- Component paths: C:/Espressif/frameworks/esp-idf-v5.2.2/components/app_trace C:/Espressif/frameworks/esp-idf-v5.2.2/components/app_update C:/Espressif/frameworks/esp-idf-v5.2.2/components/bootloader C:/Espressif/frameworks/esp-idf-v5.2.2/components/bootloader_support C:/Espressif/frameworks/esp-idf-v5.2.2/components/bt C:/Espressif/frameworks/esp-idf-v5.2.2/components/cmock C:/Espressif/frameworks/esp-idf-v5.2.2/components/console C:/Espressif/frameworks/esp-idf-v5.2.2/components/cxx C:/Espressif/frameworks/esp-idf-v5.2.2/components/driver C:/Espressif/frameworks/esp-idf-v5.2.2/components/efuse C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp-tls C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_adc C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_app_format C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_bootloader_format C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_coex C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_common C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_eth C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_event C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_gdbstub C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_hid C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_http_client C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_http_server C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_https_ota C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_https_server C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_hw_support C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_lcd C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_local_ctrl C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_mm C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_netif C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_netif_stack C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_partition C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_phy C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_pm C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_psram C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_ringbuf C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_rom C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_system C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_timer C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_wifi C:/Espressif/frameworks/esp-idf-v5.2.2/components/espcoredump C:/Espressif/frameworks/esp-idf-v5.2.2/components/esptool_py C:/Espressif/frameworks/esp-idf-v5.2.2/examples/ethernet/basic/components/ethernet_init C:/Espressif/frameworks/esp-idf-v5.2.2/components/fatfs C:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos C:/Espressif/frameworks/esp-idf-v5.2.2/components/hal C:/Espressif/frameworks/esp-idf-v5.2.2/components/heap C:/Espressif/frameworks/esp-idf-v5.2.2/components/http_parser C:/Espressif/frameworks/esp-idf-v5.2.2/components/idf_test C:/Espressif/frameworks/esp-idf-v5.2.2/components/ieee802154 C:/Espressif/frameworks/esp-idf-v5.2.2/components/json C:/Espressif/frameworks/esp-idf-v5.2.2/components/log C:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip C:/Users/Misafir/workspace/bridge/main C:/Espressif/frameworks/esp-idf-v5.2.2/components/mbedtls C:/Espressif/frameworks/esp-idf-v5.2.2/components/mqtt C:/Espressif/frameworks/esp-idf-v5.2.2/components/newlib C:/Espressif/frameworks/esp-idf-v5.2.2/components/nvs_flash C:/Espressif/frameworks/esp-idf-v5.2.2/components/nvs_sec_provider C:/Espressif/frameworks/esp-idf-v5.2.2/components/openthread C:/Espressif/frameworks/esp-idf-v5.2.2/components/partition_table C:/Espressif/frameworks/esp-idf-v5.2.2/components/perfmon C:/Espressif/frameworks/esp-idf-v5.2.2/components/protobuf-c C:/Espressif/frameworks/esp-idf-v5.2.2/components/protocomm C:/Espressif/frameworks/esp-idf-v5.2.2/components/pthread C:/Espressif/frameworks/esp-idf-v5.2.2/components/sdmmc C:/Espressif/frameworks/esp-idf-v5.2.2/components/soc C:/Espressif/frameworks/esp-idf-v5.2.2/components/spi_flash C:/Espressif/frameworks/esp-idf-v5.2.2/components/spiffs C:/Espressif/frameworks/esp-idf-v5.2.2/components/tcp_transport C:/Espressif/frameworks/esp-idf-v5.2.2/components/ulp C:/Espressif/frameworks/esp-idf-v5.2.2/components/unity C:/Espressif/frameworks/esp-idf-v5.2.2/components/usb C:/Espressif/frameworks/esp-idf-v5.2.2/components/vfs C:/Espressif/frameworks/esp-idf-v5.2.2/components/wear_levelling C:/Espressif/frameworks/esp-idf-v5.2.2/components/wifi_provisioning C:/Espressif/frameworks/esp-idf-v5.2.2/components/wpa_supplicant C:/Espressif/frameworks/esp-idf-v5.2.2/components/xtensa
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/Misafir/workspace/bridge/build
cmake --build . -- -v
[1/928] cmd.exe /C "cd /D C:\Users\Misafir\workspace\bridge\build && C:\Espressif\tools\cmake\3.24.0\bin\cmake.exe -E touch C:/Users/Misafir/workspace/bridge/build/project_elf_src_esp32.c"
[2/928] cmd.exe /C "cd /D C:\Users\Misafir\workspace\bridge\build\esp-idf\esp_system && C:\Espressif\tools\cmake\3.24.0\bin\cmake.exe -DCC=C:/Espressif/tools/xtensa-esp-elf/esp-13.2.0_20230928/xtensa-esp-elf/bin/xtensa-esp32-elf-gcc.exe -DSOURCE=C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_system/ld/esp32/memory.ld.in -DTARGET=C:/Users/Misafir/workspace/bridge/build/esp-idf/esp_system/ld/memory.ld -DCONFIG_DIR=C:/Users/Misafir/workspace/bridge/build/config -DLD_DIR=C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_system/ld -P C:/Users/Misafir/workspace/bridge/build/esp-idf/esp_system/ld/linker_script_generator.cmake"
[3/928] cmd.exe /C "cd /D C:\Users\Misafir\workspace\bridge\build\esp-idf\esp_system && C:\Espressif\tools\cmake\3.24.0\bin\cmake.exe -DCC=C:/Espressif/tools/xtensa-esp-elf/esp-13.2.0_20230928/xtensa-esp-elf/bin/xtensa-esp32-elf-gcc.exe -DSOURCE=C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_system/ld/esp32/sections.ld.in -DTARGET=C:/Users/Misafir/workspace/bridge/build/esp-idf/esp_system/ld/sections.ld.in -DCONFIG_DIR=C:/Users/Misafir/workspace/bridge/build/config -DLD_DIR=C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_system/ld -P C:/Users/Misafir/workspace/bridge/build/esp-idf/esp_system/ld/linker_script_generator.cmake"
[104/928] cmd.exe /C "cd /D C:\Users\Misafir\workspace\bridge\build\esp-idf\partition_table && python C:/Espressif/frameworks/esp-idf-v5.2.2/components/partition_table/gen_esp32part.py -q --offset 0x8000 --flash-size 2MB -- C:/Espressif/frameworks/esp-idf-v5.2.2/components/partition_table/partitions_singleapp.csv C:/Users/Misafir/workspace/bridge/build/partition_table/partition-table.bin && C:\Espressif\tools\cmake\3.24.0\bin\cmake.exe -E echo "Partition table binary generated. Contents:" && C:\Espressif\tools\cmake\3.24.0\bin\cmake.exe -E echo ******************************************************************************* && python C:/Espressif/frameworks/esp-idf-v5.2.2/components/partition_table/gen_esp32part.py -q --offset 0x8000 --flash-size 2MB -- C:/Users/Misafir/workspace/bridge/build/partition_table/partition-table.bin && C:\Espressif\tools\cmake\3.24.0\bin\cmake.exe -E echo *******************************************************************************"
# ESP-IDF Partition Table
# Name, Type, SubType, Offset, Size, Flags
nvs,data,nvs,0x9000,24K,
phy_init,data,phy,0xf000,4K,
factory,app,factory,0x10000,1M,
[105/928] ccache C:\Espressif\tools\xtensa-esp-elf\esp-13.2.0_20230928\xtensa-esp-elf\bin\xtensa-esp32-elf-gcc.exe -DESP_PLATFORM -DIDF_VER=\"v5.2.2-dirty\" -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DSOC_MMU_PAGE_SIZE=CONFIG_MMU_PAGE_SIZE -DSOC_XTAL_FREQ_MHZ=CONFIG_XTAL_FREQ -D_GLIBCXX_HAVE_POSIX_SEMAPHORE -D_GLIBCXX_USE_POSIX_SEMAPHORE -D_GNU_SOURCE -D_POSIX_READER_WRITER_LOCKS -IC:/Users/Misafir/workspace/bridge/build/config -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/mbedtls/port/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/mbedtls/mbedtls/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/mbedtls/mbedtls/library -IC:/Users/Misafir/workspace/bridge/build/esp-idf/mbedtls/mbedtls/library -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/newlib/platform_include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/config/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/config/include/freertos -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/config/xtensa/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/FreeRTOS-Kernel/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/FreeRTOS-Kernel/portable/xtensa/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/FreeRTOS-Kernel/portable/xtensa/include/freertos -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/esp_additions/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_hw_support/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_hw_support/include/soc -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_hw_support/include/soc/esp32 -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_hw_support/port/esp32/. -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/heap/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/log/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/soc/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/soc/esp32 -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/soc/esp32/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/hal/platform_port/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/hal/esp32/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/hal/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_rom/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_rom/include/esp32 -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_rom/esp32 -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_common/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_system/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_system/port/soc -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_system/port/include/private -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/xtensa/esp32/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/xtensa/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/xtensa/deprecated_include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/include/apps -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/include/apps/sntp -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/lwip/src/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/port/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/port/freertos/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/port/esp32xx/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/port/esp32xx/include/arch -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/port/esp32xx/include/sys -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/mbedtls/mbedtls/3rdparty/everest/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/mbedtls/mbedtls/3rdparty/p256-m -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/mbedtls/mbedtls/3rdparty/p256-m/p256-m -mlongcalls -Wno-frame-address -fno-builtin-memcpy -fno-builtin-memset -fno-builtin-bzero -fno-builtin-stpcpy -fno-builtin-strncpy -Wall -Wextra -Wwrite-strings -Wformat=2 -Wno-format-nonliteral -Wvla -Wlogical-op -Wshadow -Wformat-signedness -Wformat-overflow=2 -Wformat-truncation -Werror -Wmissing-declarations -Wmissing-prototypes -fdiagnostics-color=always -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=unused-but-set-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -Wno-enum-conversion -gdwarf-4 -ggdb -Og -fno-shrink-wrap -fmacro-prefix-map=C:/Users/Misafir/workspace/bridge=. -fmacro-prefix-map=C:/Espressif/frameworks/esp-idf-v5.2.2=/IDF -fstrict-volatile-bitfields -fno-jump-tables -fno-tree-switch-conversion -std=gnu17 -Wno-old-style-declaration -MD -MT esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/C_/Espressif/frameworks/esp-idf-v5.2.2/components/mbedtls/port/md/esp_md.c.obj -MF esp-idf\mbedtls\mbedtls\library\CMakeFiles\mbedcrypto.dir\C_\Espressif\frameworks\esp-idf-v5.2.2\components\mbedtls\port\md\esp_md.c.obj.d -o esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/C_/Espressif/frameworks/esp-idf-v5.2.2/components/mbedtls/port/md/esp_md.c.obj -c C:/Espressif/frameworks/esp-idf-v5.2.2/components/mbedtls/port/md/esp_md.c
[259/928] ccache C:\Espressif\tools\xtensa-esp-elf\esp-13.2.0_20230928\xtensa-esp-elf\bin\xtensa-esp32-elf-gcc.exe -DESP_PLATFORM -DIDF_VER=\"v5.2.2-dirty\" -DSOC_MMU_PAGE_SIZE=CONFIG_MMU_PAGE_SIZE -DSOC_XTAL_FREQ_MHZ=CONFIG_XTAL_FREQ -D_GLIBCXX_HAVE_POSIX_SEMAPHORE -D_GLIBCXX_USE_POSIX_SEMAPHORE -D_GNU_SOURCE -D_POSIX_READER_WRITER_LOCKS -IC:/Users/Misafir/workspace/bridge/build/config -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/hal/platform_port/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/hal/esp32/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/hal/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/newlib/platform_include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/config/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/config/include/freertos -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/config/xtensa/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/FreeRTOS-Kernel/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/FreeRTOS-Kernel/portable/xtensa/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/FreeRTOS-Kernel/portable/xtensa/include/freertos -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/esp_additions/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_hw_support/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_hw_support/include/soc -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_hw_support/include/soc/esp32 -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_hw_support/port/esp32/. -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/heap/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/log/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/soc/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/soc/esp32 -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/soc/esp32/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_rom/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_rom/include/esp32 -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_rom/esp32 -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_common/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_system/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_system/port/soc -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_system/port/include/private -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/xtensa/esp32/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/xtensa/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/xtensa/deprecated_include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/include/apps -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/include/apps/sntp -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/lwip/src/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/port/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/port/freertos/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/port/esp32xx/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/port/esp32xx/include/arch -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/port/esp32xx/include/sys -mlongcalls -Wno-frame-address -fno-builtin-memcpy -fno-builtin-memset -fno-builtin-bzero -fno-builtin-stpcpy -fno-builtin-strncpy -fdiagnostics-color=always -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=unused-but-set-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -Wno-enum-conversion -gdwarf-4 -ggdb -Og -fno-shrink-wrap -fmacro-prefix-map=C:/Users/Misafir/workspace/bridge=. -fmacro-prefix-map=C:/Espressif/frameworks/esp-idf-v5.2.2=/IDF -fstrict-volatile-bitfields -fno-jump-tables -fno-tree-switch-conversion -std=gnu17 -Wno-old-style-declaration -MD -MT esp-idf/hal/CMakeFiles/__idf_hal.dir/mpi_hal.c.obj -MF esp-idf\hal\CMakeFiles\__idf_hal.dir\mpi_hal.c.obj.d -o esp-idf/hal/CMakeFiles/__idf_hal.dir/mpi_hal.c.obj -c C:/Espressif/frameworks/esp-idf-v5.2.2/components/hal/mpi_hal.c
[260/928] ccache C:\Espressif\tools\xtensa-esp-elf\esp-13.2.0_20230928\xtensa-esp-elf\bin\xtensa-esp32-elf-gcc.exe -DESP_PLATFORM -DIDF_VER=\"v5.2.2-dirty\" -DSOC_MMU_PAGE_SIZE=CONFIG_MMU_PAGE_SIZE -DSOC_XTAL_FREQ_MHZ=CONFIG_XTAL_FREQ -D_GLIBCXX_HAVE_POSIX_SEMAPHORE -D_GLIBCXX_USE_POSIX_SEMAPHORE -D_GNU_SOURCE -D_POSIX_READER_WRITER_LOCKS -IC:/Users/Misafir/workspace/bridge/build/config -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/hal/platform_port/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/hal/esp32/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/hal/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/newlib/platform_include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/config/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/config/include/freertos -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/config/xtensa/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/FreeRTOS-Kernel/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/FreeRTOS-Kernel/portable/xtensa/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/FreeRTOS-Kernel/portable/xtensa/include/freertos -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/esp_additions/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_hw_support/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_hw_support/include/soc -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_hw_support/include/soc/esp32 -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_hw_support/port/esp32/. -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/heap/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/log/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/soc/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/soc/esp32 -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/soc/esp32/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_rom/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_rom/include/esp32 -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_rom/esp32 -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_common/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_system/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_system/port/soc -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_system/port/include/private -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/xtensa/esp32/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/xtensa/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/xtensa/deprecated_include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/include/apps -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/include/apps/sntp -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/lwip/src/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/port/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/port/freertos/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/port/esp32xx/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/port/esp32xx/include/arch -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/port/esp32xx/include/sys -mlongcalls -Wno-frame-address -fno-builtin-memcpy -fno-builtin-memset -fno-builtin-bzero -fno-builtin-stpcpy -fno-builtin-strncpy -fdiagnostics-color=always -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=unused-but-set-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -Wno-enum-conversion -gdwarf-4 -ggdb -Og -fno-shrink-wrap -fmacro-prefix-map=C:/Users/Misafir/workspace/bridge=. -fmacro-prefix-map=C:/Espressif/frameworks/esp-idf-v5.2.2=/IDF -fstrict-volatile-bitfields -fno-jump-tables -fno-tree-switch-conversion -std=gnu17 -Wno-old-style-declaration -MD -MT esp-idf/hal/CMakeFiles/__idf_hal.dir/adc_hal.c.obj -MF esp-idf\hal\CMakeFiles\__idf_hal.dir\adc_hal.c.obj.d -o esp-idf/hal/CMakeFiles/__idf_hal.dir/adc_hal.c.obj -c C:/Espressif/frameworks/esp-idf-v5.2.2/components/hal/adc_hal.c
FAILED: esp-idf/hal/CMakeFiles/__idf_hal.dir/adc_hal.c.obj
C:/Espressif/frameworks/esp-idf-v5.2.2/components/hal/adc_hal.c:360:1: fatal error: error writing to C:\Users\Misafir\AppData\Local\Temp\ccQJQTbU.s: No error
360 | }
compilation terminated.
[261/928] ccache C:\Espress
[275/928] ccache C:\Espressif\tools\xtensa-esp-elf\esp-13.2.0_20230928\xtensa-esp-elf\bin\xtensa-esp32-elf-gcc.exe -DESP_PLATFORM -DIDF_VER=\"v5.2.2-dirty\" -DSOC_MMU_PAGE_SIZE=CONFIG_MMU_PAGE_SIZE -DSOC_XTAL_FREQ_MHZ=CONFIG_XTAL_FREQ -D_GLIBCXX_HAVE_POSIX_SEMAPHORE -D_GLIBCXX_USE_POSIX_SEMAPHORE -D_GNU_SOURCE -D_POSIX_READER_WRITER_LOCKS -IC:/Users/Misafir/workspace/bridge/build/config -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/hal/platform_port/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/hal/esp32/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/hal/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/newlib/platform_include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/config/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/config/include/freertos -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/config/xtensa/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/FreeRTOS-Kernel/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/FreeRTOS-Kernel/portable/xtensa/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/FreeRTOS-Kernel/portable/xtensa/include/freertos -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos/esp_additions/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_hw_support/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_hw_support/include/soc -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_hw_support/include/soc/esp32 -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_hw_support/port/esp32/. -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/heap/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/log/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/soc/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/soc/esp32 -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/soc/esp32/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_rom/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_rom/include/esp32 -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_rom/esp32 -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_common/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_system/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_system/port/soc -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_system/port/include/private -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/xtensa/esp32/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/xtensa/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/xtensa/deprecated_include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/include/apps -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/include/apps/sntp -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/lwip/src/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/port/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/port/freertos/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/port/esp32xx/include -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/port/esp32xx/include/arch -IC:/Espressif/frameworks/esp-idf-v5.2.2/components/lwip/port/esp32xx/include/sys -mlongcalls -Wno-frame-address -fno-builtin-memcpy -fno-builtin-memset -fno-builtin-bzero -fno-builtin-stpcpy -fno-builtin-strncpy -fdiagnostics-color=always -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=unused-but-set-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -Wno-enum-conversion -gdwarf-4 -ggdb -Og -fno-shrink-wrap -fmacro-prefix-map=C:/Users/Misafir/workspace/bridge=. -fmacro-prefix-map=C:/Espressif/frameworks/esp-idf-v5.2.2=/IDF -fstrict-volatile-bitfields -fno-jump-tables -fno-tree-switch-conversion -std=gnu17 -Wno-old-style-declaration -MD -MT esp-idf/hal/CMakeFiles/__idf_hal.dir/emac_hal.c.obj -MF esp-idf\hal\CMakeFiles\__idf_hal.dir\emac_hal.c.obj.d -o esp-idf/hal/CMakeFiles/__idf_hal.dir/emac_hal.c.obj -c C:/Espressif/frameworks/esp-idf-v5.2.2/components/hal/emac_hal.c
FAILED: esp-idf/hal/CMakeFiles/__idf_hal.dir/emac_hal.c.obj
C:/Espressif/frameworks/esp-idf-v5.2.2/components/hal/emac_hal.c:732:1: fatal error: error writing to C:\Users\Misafir\AppData\Local\Temp\ccmuMqoT.s: No error
732 | }
[293/928] cmd.exe /C "cd /D C:\Users\Misafir\workspace\bridge\build\bootloader && C:\Espressif\tools\cmake\3.24.0\bin\cmake.exe -DSDKCONFIG=C:/Users/Misafir/workspace/bridge/sdkconfig -DIDF_PATH=C:/Espressif/frameworks/esp-idf-v5.2.2 -DIDF_TARGET=esp32 -DPYTHON_DEPS_CHECKED=1 -DPYTHON=python -DEXTRA_COMPONENT_DIRS=C:/Espressif/frameworks/esp-idf-v5.2.2/components/bootloader -DPROJECT_SOURCE_DIR=C:/Users/Misafir/workspace/bridge -DIGNORE_EXTRA_COMPONENT= -GNinja C:/Espressif/frameworks/esp-idf-v5.2.2/components/bootloader/subproject && C:\Espressif\tools\cmake\3.24.0\bin\cmake.exe -E touch C:/Users/Misafir/workspace/bridge/build/bootloader-prefix/src/bootloader-stamp/bootloader-configure"
-- Bootloader project name: "bootloader" version: 1
-- Adding linker script C:/Espressif/frameworks/esp-idf-v5.2.2/components/bootloader/subproject/main/ld/esp32/bootloader.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v5.2.2/components/bootloader/subproject/main/ld/esp32/bootloader.rom.ld
-- Components: bootloader bootloader_support efuse esp_app_format esp_bootloader_format esp_common esp_hw_support esp_rom esp_system esptool_py freertos hal log main micro-ecc newlib partition_table soc spi_flash xtensa
-- Component paths: C:/Espressif/frameworks/esp-idf-v5.2.2/components/bootloader C:/Espressif/frameworks/esp-idf-v5.2.2/components/bootloader_support C:/Espressif/frameworks/esp-idf-v5.2.2/components/efuse C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_app_format C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_bootloader_format C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_common C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_hw_support C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_rom C:/Espressif/frameworks/esp-idf-v5.2.2/components/esp_system C:/Espressif/frameworks/esp-idf-v5.2.2/components/esptool_py C:/Espressif/frameworks/esp-idf-v5.2.2/components/freertos C:/Espressif/frameworks/esp-idf-v5.2.2/components/hal C:/Espressif/frameworks/esp-idf-v5.2.2/components/log C:/Espressif/frameworks/esp-idf-v5.2.2/components/bootloader/subproject/main C:/Espressif/frameworks/esp-idf-v5.2.2/components/bootloader/subproject/components/micro-ecc C:/Espressif/frameworks/esp-idf-v5.2.2/components/newlib C:/Espressif/frameworks/esp-idf-v5.2.2/components/partition_table C:/Espressif/frameworks/esp-idf-v5.2.2/components/soc C:/Espressif/frameworks/esp-idf-v5.2.2/components/spi_flash C:/Espressif/frameworks/esp-idf-v5.2.2/components/xtensa
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/Misafir/workspace/bridge/build/bootloader
Build complete (2 errors, 0 warnings): C:\Users\Misafir\workspace\bridge\build
Total time taken to build the project: 9,807 ms
Can not build any project [IDFGH-13323]
- ESP_Roland
Re: Can not build any project
Could you try to run the following and see if it helps?
I would also recommend to check the output of "git status" and see if any files have been changed. Especially those two in "components/hal" for which the error is reported.
ccache -C
Re: Can not build any project [IDFGH-13323]
ccache -C didn't work, git status output is below. Btw it is fresh install.
C:\Espressif\frameworks\esp-idf-v5.2.2>git status
Not currently on any branch.
Changes not staged for commit:
(use "git add <file>..." to update what will be committed)
(use "git restore <file>..." to discard changes in working directory)
(commit or discard the untracked or modified content in submodules)
modified: components/bt/host/nimble/nimble (modified content)
modified: examples/build_system/cmake/idf_as_lib/build-esp32.sh
modified: examples/build_system/cmake/idf_as_lib/build-esp32c2.sh
modified: examples/build_system/cmake/idf_as_lib/build-esp32c3.sh
modified: examples/build_system/cmake/idf_as_lib/build-esp32c6.sh
modified: examples/build_system/cmake/idf_as_lib/build-esp32h2.sh
modified: examples/build_system/cmake/idf_as_lib/build-esp32s2.sh
modified: examples/build_system/cmake/idf_as_lib/build-esp32s3.sh
modified: examples/build_system/cmake/idf_as_lib/run-esp32c2.sh
modified: examples/build_system/cmake/idf_as_lib/run-esp32c3.sh
modified: examples/build_system/cmake/idf_as_lib/run-esp32c6.sh
modified: examples/build_system/cmake/idf_as_lib/run-esp32h2.sh
modified: examples/build_system/cmake/idf_as_lib/run-esp32s2.sh
modified: examples/build_system/cmake/idf_as_lib/run-esp32s3.sh
no changes added to commit (use "git add" and/or "git commit -a")
Users browsing this forum: No registered users and 15 guests
