Hello
I would like to know how to use extra components such as esp-protocols repository (https://github.com/espressif/esp-protocols) with the vscode IDF extension.
Where to add the path to the repo so that my project can find and use the components ? I don't found the information.
Joel
Using extra components esp-protocols with vscode extension
Re: Using extra components esp-protocols with vscode extension
You can try to use the ESP-IDF: Show Component Registry command to open the IDF Component manager website inside vscode. Find the asp-protocols components you want like esp_modem. Click the install button. this will update your src/main/idf_component.yml file.
Use the component in your project. When you build the project, the build system will call the component manager python package and download the component into a managed_components directory in your project.
You can also manually download the component directory and reference into your project using the CMakeLists.txt to specify this component.
Links for reference:
https://docs.espressif.com/projects/esp ... nager.html
https://docs.espressif.com/projects/esp ... ists-files
Hope this helps. Let us know how it goes.
Users browsing this forum: No registered users and 7 guests
