I am having an issue when importing an existing ESP32 project into the ESP-IDF with Eclipse CDT 09-2022 Version.
When trying to build any project I get the following error in console "No Toolchain found for Target Local".
I also am not able to change the launch target to "ESP" as I can with example projects.
I just reinstalled IDF 4.42 and CDT V0922 along with Java SE.
Any help would be greatly appreciated!
Thanks,
Steve
Issue when trying to import existing projects into IDF
- Error Message
- Eclipse Error No Toolchain.PNG (134.27 KiB) Viewed 2659 times
Re: Issue when trying to import existing projects into IDF
How did you import the project? if you've imported using this approach, the launch configuration for the project is created automatically and you will see default launch targets.
Users browsing this forum: No registered users and 14 guests
