Hi team,
Am working on ESP-ADF environment, trying to add feature of "WAKE WORD DETECTION" using ESP32-LyraT-V4.3 development board
using default memory partition given in example code (partitions_esp32.csv) file from %ADF_PATH% =C:\Espressif\frameworks\esp-adf\examples\speech_recognition\wwe, am getting below error message
1) Is SD card interface required to test wake word ?
2) What is the memory partition to be done for SPIFFS, to store MODEL data and Flash_tone given in memory partition (partitions_esp32.csv) or can i use default memory partition ?
3) What are the Necessary Configurations to be done to test this example ?
Please could you resolve my issue ASAP ..
Thanking you
Suraj, N
ESP32 Wake Word Detection
- ESP32_LyraT_board_wwe_SDcard.txt
- (6.5 KiB) Downloaded 1092 times
Re: ESP32 Wake Word Detection
--> No, it is not must.
--> Pelease use default memory partition, refer to this dome
--> Sorry, I can't play files in the forum. The necessary configurations are in the default configuration of demo.
In addition, if you need to experience a better wake-up word effect, it is recommended that you use esp32-s3 to develop and experience it. which uses mic array and has better algorithm optimization.
https://docs.espressif.com/projects/esp ... rvo-2.html
I am working with ESP32-S3-Korvo-2 (V 3.1). I have configured my wake word as "Hi ESP" and flashed my wake word detection code. But my wake word voice command is not detected. I could see the ES7210: Open fail and ES8311: Open fail in the logs. I have attached the log herewith, It would be helpful if I know why it is failing.
Thank you.
Thank you.
Users browsing this forum: No registered users and 7 guests
